Control the acquisition server from command line
Posted: Sun Oct 03, 2021 2:10 pm
Hello,
I am doing my final carrer project and I am adapting some parts of openvibe, it would be great if I could launch openvibe entirely from the command line. I know that this is possible for the designer application but, is there a way to start the acquisition server from the command line entirely?, I mean with not having to press the "connect + play" buttons. Is there a way to not show that dialog box either ?
I've been looking for the question on the forum but I haven't seen any information about it.
The only thing I found was in the changelog for version 1.0 (viewtopic.php?p=14066) it said:
"- Applications: Acquisition Server autoplay via config token"
Does that functionality still exist?
How could I use it?
I am using windows openvibe version 3.1.0 (64bit) and I can compile from source if needed.
Great software by the way.
How could I use it?
