Help in Building Acquisition Server for ADS1256 24 bit Waveshare module.
Posted: Tue Apr 13, 2021 9:05 am
I am working on integration of Waveshare ADS1256 High Precision AD/DA module for Rasberry Pi with OpenVibe. I have ADS1256 Driver for WiringPi which are written in C language as of openvibe. I dont have a grip on C language. So i need help. With C coding and WiringPi driver i will be able to get data of 8 channel in a variable forum which i already have done in python. But I want to stream it in the acquisition server. From skeleton Generator, I have made the driver outline. As WiringPi Driver has already build libraries for ADS1256 acquisition in C, the suitable approach which I think is that I should call combine the code and call the libraries of already build driver (WiringPi). But I'm unable to understand, the structure because mostlm openvibe drivers are made for COM ports and this is using GPIOs. So I am stuck at the very Beginning. Need Help to get started. I am attaching the link of ADS1256 driver.
https://github.com/waveshare/High-Preci ... 6/wiringpi
I want to know the direction and guidance to make it. I know ADS1256 module has all the requirements for EEG acquisition and if the driver would be made, BCI can be made possible with only 150 $ cost. So Please help me what should I do with available drivers. I'm stuck at very beginning. And also tell me which device driver on Openvibe would be suitable for me as reference (not COM Port but GPIO).
