I am using Ant-Neuro version of TMSI Refa-Amp.
I saw the current version of acquisition server only support eego of Ant-Neuro.
When I try to connect Refa Amp using TMSi driver, it shows -8 error.
It shows the device as 'usb - ' and same result when tested with TMSi Matlab SDK.
Is there any possibility of connect ANT-Neuro OEM Refa 70ch Amp?
I found below link
viewtopic.php?f=5&t=238&start=45
and my amp is exactly serial # with 120~
