Hypnodyne ZMax Compatibility
HypnodyneDev
Post by HypnodyneDev »
Hi all :)
I work in a lab that recently acquired a Hypnodyne ZMax (http://hypnodynecorp.com/) and am exploring ways to use it. OpenVibe looks great, but I've never used it before.
It seems the only way to use OpenVibe with the ZMax would be to write my own C++ software from scratch, right? The ZMax isn't on the approved hardware list so I'm assuming none of the OpenVibe applications can interface.
Please let me know if there's any other way to interact with OpenVibe using a ZMax! Thanks!
Re: Hypnodyne ZMax Compatibility
Yes, You have 2 main possibilities, code your driver for Zmax (and you can share it after^^). Or Find a way to send data by LSL (it's write unstable for this driver because not enough test to validate his quality)
HypnodyneDev
Thank you for your response!
Can you clarify what you mean by "send data by LSL"?
LSL is Lab Streaming Layer, if your product can send value by lsl you can reveive this directly on openvibe
