Acquisition Server LSL: Error resolving signal with name []
matteo.mazzanti
Post by matteo.mazzanti »
Dears,
using the Acquisition Server, I would like to acquire data through the LSL driver, but I cannot.
Unfortunately, on the the Acquisition Server panel, when I click "connect", the following error is logged:
[  INF  ] Connecting to device [LabStreamingLayer (LSL)]...
[ ERROR ] Error resolving signal stream with name []
[  INF  ] Disconnecting.
Trying to set the parameter into the driver's properties panel is not allowed, as the parameter's value drop-down menu is disabled.
In other words, it is not possible to set the Signal Stream parameter from the driver property panel.
https://ibb.co/wQFQPy6
My setup:
Ubuntu 16.10
OV: 2.2.0
Self built
UPDATE 2019-05-04
I have also tried OV v2.1 self built on Ubuntu 16.10 and OV v2.2 windows installer on Windows 10.
Same results. The LSL driver cannot be started due to the same error:
Thanks in advice for helping.
Matteo Mazzanti
