While using the Acquisition server for a SSVEP experiment, I noticed a strange behavior for impedance checker in the Gipsa-Lab gUSBAmp driver.
the electrodes are distributed in parietal and occipital regions of the brain, when using that checker the impedance levels are unstable and higher than the 5kOhm, however when switching the driver for the legacy one the checker displays good stable impedance levels (below 5 kOhm).
The OpenVibe version I use is the latest: 2.2.0 64bit on windows 7.
Impedance checker issue using gUSBAmp driver
