I have installed OpenVibe 1.3 on Ubuntu 16.04 in Raspberry Pi 3 b+. I connected the Neurosky Mindwave headset with Raspberry Pi through Bluetooth.
After launching the acquisition server, Neurosky is not listed in the device. What should be done to enable it?
Neurosky missing in Acquisition Server
Re: Neurosky missing in Acquisition Server
For some product, we can't give the source code to compile the driver.... Sorry business problems. You can contact your reseller and ask for the procedure to install the API for it to be recognized by openvibe
But it works perfectly on Windows 10. Neurosky Headset was listed in the server list and I was able to connect and get reading from it.
So, am I missing something with the installation here.
On windows 10 you have the setup OpenViBE and we can't propose the source to compile but we can propose a precompiled driver on setup.exe. This is the illogicality of use rights
