Problem detecting gNautilus
Posted: Wed Dec 19, 2018 4:28 pm
Hi everyone,
I have some difficulties to connect the Gtech Nautilus device to the acquisition server.
The gNEEDacess is well installed and works normally, but I can't connect the device.
The following error message is display :
[ERROR] No Gtech device found
[ERROR] connection failed
I tested with the generic oscillator and it works.
Is there some configuration steps required before using the device ?
I found the following documentation (http://openvibe.inria.fr/openvibe/wp-co ... enViBE.pdf) Is this still up to date?
Thank you for your time.
Thibault.
(Moderator: moved post to its own topic)
Thibault.
