Problem detecting gNautilus
tchabin
Post by tchabin »
Hi everyone,
I have some difficulties to connect the Gtech Nautilus device to the acquisition server.
The gNEEDacess is well installed and works normally, but I can't connect the device.
The following error message is display :
[ERROR] No Gtech device found
[ERROR] connection failed
I tested with the generic oscillator and it works.
Is there some configuration steps required before using the device ?
I found the following documentation (http://openvibe.inria.fr/openvibe/wp-co ... enViBE.pdf) Is this still up to date?
Thank you for your time.
Thibault.
(Moderator: moved post to its own topic)
Re: Problem detecting gNautilus
I had several problems with the Nautilus. Turn on your headset before launching the acquisition server. I also click on "driver properties" before doing "connect".
tchabin
Post by tchabin »
Hi Thibaut,
It works,
Thanks.
Thibault.
