OpenViBE forum
The OpenViBE community
It is currently Thu Jun 20, 2019 1:04 pm
Post new topic Reply to topic  [ 8 posts ]
Author Message
PostPosted: Mon May 28, 2018 9:10 pm
Offline
Hi,
I'm trying to use Brain Products actiCHamp with OpenViBE 2.1. I am able to successfully connect and receive data from the device using OpenViBE for BrainProducts 1.2.0.1 (based on OpenViBE 0.17.0) without any effort. Using OpenViBE 2.1, I am able to connect with the device and run impedance check using a native actiCHamp driver but I have an issue with "Timeout after 5000 milliseconds" after pushing Play. I bet this is a problem with default headset configuration or I'm missing something?
Top
 Profile
PostPosted: Tue May 29, 2018 8:47 am
Offline
Hello,
we don't unfortunately have the device at Inria so we cannot test it, and I hear the support contract between Mensia and Brain Products has expired. Have you asked the manufacturer if they have an idea?
Best,
Jussi
Top
 Profile
PostPosted: Tue May 29, 2018 8:56 am
Offline
I will ask Brain Products than and let you know. Anyway, I was surprised by this Timeout regarding OpenViBE release notes saying: "This release is the conclusion of the CertiViBE project -- two years of tight collaboration between Inria & Mensia Technologies." :)
Top
 Profile
PostPosted: Tue May 29, 2018 8:59 am
Offline
This is a bit off topic, but it might be interesting to know that the certivibe project did not include acquisition at all. Acquisition Server and all device drivers were outside its scope.
For those interested, the actual scope can be seen in the structure of the gitlab code repository: sdk is firmly certivibe, designer is following similar processes, whereas meta and extras (which contains the acquisition) were not involved in the project.
Best,
Jussi
Top
 Profile
PostPosted: Fri Jun 01, 2018 9:08 am
Offline
Answer from Brain Products technical support (techsup@brainproducts.com) after exchanging a few mails:
As the system works with both Recorder and 0.17 of OpenViBE Acquisition Server, it seems it is an OpenVIBE 2.1 specific issue. We can't provide help. Please contact INRIA. We would provide a loan actiCHAMP if they need it for debugging.
Top
 Profile
PostPosted: Thu Jun 07, 2018 3:25 pm
Offline
Finally, I worked around the problem by using Acquisition Server from OpenViBE for BrainProducts (based on OpenViBE 0.17.0) with Acquisition client box from OpenViBE 2.1.
Top
 Profile
PostPosted: Thu Jun 07, 2018 3:28 pm
Offline
Thanks for the feedback! We currently have no resources to debug issues at Inria regarding drivers/devices that we don't ourselves use, but this might change in the future if the OpenViBE consortium launches.
Before that, the best we can do is to include patches if anybody submits them.
ps. the email address seems to be one of brain products, not mensia. They are quite different companies. :)
Top
 Profile
PostPosted: Thu Jun 07, 2018 3:50 pm
Offline
Of course, you are right, I've edited my posts to avoid confusion.
Top
 Profile
Who is online
Search for:
Jump to:
Americanized by Maƫl Soucaze.
