Missing boxes on Windows
Posted: Sat Apr 07, 2018 8:39 am
Good morning !
I have a new problem after my compilation: boxes Acquisition, Samples, VRPN and Visualisation are missing.
But when I launch openvibe-designer from dist\extras-Release I don't get any error concerning plugins.
0 metaboxes are added, is this the problem ? (the final error comes from an old test.mxs I have deleted a few days ago):
[ INF ] Adding plugins from [C:/work/openvibe/dist/sdk-Release/bin/openvibe-plugins-*.dll]
[ INF ] Added 10 plugin object descriptor(s) from [C:/work/openvibe/dist/sdk-Release/bin/openvibe-plugins-sdk-classification.dll]
[ INF ] Added 1 plugin object descriptor(s) from [C:/work/openvibe/dist/sdk-Release/bin/openvibe-plugins-sdk-data-generation.dll]
[ INF ] Added 1 plugin object descriptor(s) from [C:/work/openvibe/dist/sdk-Release/bin/openvibe-plugins-sdk-feature-extraction.dll]
[ INF ] Added 9 plugin object descriptor(s) from [C:/work/openvibe/dist/sdk-Release/bin/openvibe-plugins-sdk-file-io.dll]
[ INF ] Added 24 plugin object descriptor(s) from [C:/work/openvibe/dist/sdk-Release/bin/openvibe-plugins-sdk-signal-processing.dll]
[ INF ] Added 5 plugin object descriptor(s) from [C:/work/openvibe/dist/sdk-Release/bin/openvibe-plugins-sdk-stimulation.dll]
[ INF ] Added 19 plugin object descriptor(s) from [C:/work/openvibe/dist/sdk-Release/bin/openvibe-plugins-sdk-stream-codecs.dll]
[ INF ] Added 2 plugin object descriptor(s) from [C:/work/openvibe/dist/sdk-Release/bin/openvibe-plugins-sdk-streaming.dll]
[ INF ] Added 3 plugin object descriptor(s) from [C:/work/openvibe/dist/sdk-Release/bin/openvibe-plugins-sdk-tools.dll]
[ INF ] Adding metaboxes from [C:/work/openvibe/dist/sdk-Release/share/openvibe/metaboxes/;C:/Users/alice/AppData/Roaming/openvibe-2.0/metaboxes/]
[ INF ] Added 0 metaboxes from [C:/work/openvibe/dist/sdk-Release/share/openvibe/metaboxes/]
[ INF ] Added 0 metaboxes from [C:/Users/alice/AppData/Roaming/openvibe-2.0/metaboxes/]
[ ERROR ] {Error description} : {Can not open scenario file 'C:/Users/alice/Documents/Stage ENS Lyon/Logiciel/OpenVibe/test.mxs'}, {Error type} : {ErrorType::BadFileRead (code 40)}, {Error location} : {C:\work\openvibe\sdk\kernel\src\kernel\scenario\ovkCScenarioManager.cpp::215}
[ ERROR ] Importing scenario from file [C:/Users/alice/Documents/Stage ENS Lyon/Logiciel/OpenVibe/test.mxs] failed... Current file either is corrupted or is not compatible with the selected scenario importer (ie not an OpenViBE scenario file)
[WARNING] Failed to restore scenario [C:/Users/alice/Documents/Stage ENS Lyon/Logiciel/OpenVibe/test.mxs]
[ INF ] Initialization took 3835 ms[/size]
Thank you very much,
Best,
Alice
Best,
Alice
