Want to export EDF file saved from OpenVIBE to EEGLAB
Posted: Thu Mar 29, 2018 9:39 am
Hi, I am a student currently working on a BCI project. I am using a BrainMaster Discovery 24E amplifier and used OpenVIBE as an acquisition server for online processing of my BCI experimental set up. However for offline processing I have switched to BCILAB. I earlier tried to work with EEGLAB but it has limited tools for processing of BCI experimental data (ERD/ERS quantification). I was able to export EDF file saved from OpenVIBE to EEGLAB however I am not sure it reads the exact channel location as provided by the amplifier company (BrainMaster) as EEGLAB can read EDF format of Biosemi by default. However when I export same EDF file to BCILAB, for Offline processing (e.g. log-bandpower method) it does not work and give me following errors:
Also to let you know the sample files under the folder 'Tutorial' in BCILAB zipped folder also does not work with BCILAB. I do not know is there any installation error or what. At least the offline processing on given sample data should have worked. Kindly help me out with this. I have wasted so many days finding solution to it but all in vain.
