Page 1 of 1
Error building in raspberry pi3
Posted: Tue Feb 06, 2018 2:17 pm
by b0rn4
Hi,
I'm trying to build OpenViBE in my raspberry pi, but after install dependencies successfully this error results.
Hope someone can help me.
Thanks!
SO: Ubuntu 16.04
Hardware: Raspberry pi3
Code: Select all
juan@juan-desktop:~/OpenBCI/openvibe-2.0.1-src$ sudo ./build.sh
Building sdk
Build with parameters:
[build-type] = Release
[build-dir] = /home/juan/OpenBCI/openvibe-2.0.1-src/build/sdk-Release
[dependencies-dir token] = -DOV_CUSTOM_DEPENDENCIES_PATH=/home/juan/OpenBCI/openvibe-2.0.1-src/dependencies
[install-dir] = /home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release
[test data directory token] = -DOVT_TEST_DATA_DIR=/home/juan/OpenBCI/openvibe-2.0.1-src/dependencies/test-input
[test output files directory] = /home/juan/OpenBCI/openvibe-2.0.1-src/build/sdk-Release/validation-test-output/
[build unit] = 1
[build validation] = 1
[brand name] = OpenViBE
[user data subdirectory] = -DOV_CONFIG_SUBDIR=openvibe-2.0
[display-error-location] = ON
Generating build system files with cmake...
-- Could NOT find Git (missing:  GIT_EXECUTABLE)
CMake Warning at cmake-modules/Utilities.cmake:15 (message):
  Git not found, set version to 0.0.0
Call Stack (most recent call first):
  CMakeLists.txt:13 (set_version)
-- BUILDING VERSION OpenViBE SDK: 0.0.0.0 Branch : unknown~0
-- Appending compilation flags...
-- Compilation flags used at source root:
--   COMPILE_DEFINITIONS = 'OV_CONFIG_SUBDIR="openvibe-2.0";OV_PROJECT_NAME="OpenVIBE";OV_VERSION_MAJOR="0";OV_VERSION_MINOR="0";OV_VERSION_PATCH="0";OV_CMAKE_PATH_ROOT="/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release";OV_CMAKE_PATH_BIN="/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/bin";OV_CMAKE_PATH_LIB="/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/lib";OV_CMAKE_PATH_DATA="/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/share/openvibe"'
--   CMAKE_CXX_FLAGS = ' -fopenmp -Wall -msse2'
--   CMAKE_CXX_FLAGS_RELEASE = '-O3 -DNDEBUG'
--   CMAKE_CXX_FLAGS_DEBUG = '-g'
--   Found boost includes...
--   Found openvibe-common...
--   Found dl...
--   Found pthread...
--   Found OpenViBE... [/home/juan/OpenBCI/openvibe-2.0.1-src/sdk/openvibe]
--   Found OpenViBE module FS... openvibe-module-fs
--   Found OpenViBE module System...
--   Found OpenViBE module XML...
--   Found dl...
--   Found pthread...
-- CUSTOM DOCUMENTATION ENABLED FOR ebml
--   Found OpenViBE module FS... openvibe-module-fs-static
-- Boost version: 1.58.0
-- Found the following Boost libraries:
--   filesystem
--   system
--   Found pthread...
--   Found expat...
-- Project ebml has custom documentation
--   Found expat...
--   filesystem
--   system
--   Found pthread...
--   Found OpenViBE module EBML...
--   filesystem
--   system
--   Found pthread...
-- Documentation files found in /home/juan/OpenBCI/openvibe-2.0.1-src/sdk/plugins/processing/streaming/doc
--   Found openvibe-toolkit...  /home/juan/OpenBCI/openvibe-2.0.1-src/sdk/toolkit/include
-- Documentation files found in /home/juan/OpenBCI/openvibe-2.0.1-src/sdk/plugins/processing/data-generation/doc
-- Documentation files found in /home/juan/OpenBCI/openvibe-2.0.1-src/sdk/plugins/processing/signal-processing/doc
-- Found eigen3... [/usr/local/include/eigen3]
-- Documentation files found in /home/juan/OpenBCI/openvibe-2.0.1-src/sdk/plugins/processing/file-io/doc
--   Found OpenViBE module CSV...
--   Link openvibe-module-csv
--   Found xerces...
-- Documentation files found in /home/juan/OpenBCI/openvibe-2.0.1-src/sdk/plugins/processing/classification/doc
-- Documentation files found in /home/juan/OpenBCI/openvibe-2.0.1-src/sdk/plugins/processing/feature-extraction/doc
-- Documentation files found in /home/juan/OpenBCI/openvibe-2.0.1-src/sdk/plugins/processing/tools/doc
-- Documentation files found in /home/juan/OpenBCI/openvibe-2.0.1-src/sdk/plugins/processing/stimulation/doc
--   filesystem
--   system
--   Found pthread...
--   filesystem
--   system
--   Found pthread...
--   filesystem
--   system
--   Found pthread...
--   Found OpenViBE module Socket... /openvibe-module-socket
-- Found Python3 at /usr/bin/python3
-- Configuring done
-- Generating done
-- Build files have been written to: /home/juan/OpenBCI/openvibe-2.0.1-src/build/sdk-Release
Generation succeeded!
Building project...
[6/339] Building CXX object build-tool...n-generator.dir/src/ovbt_sg_main.cpp.o
FAILED: /usr/bin/c++   -DBRAND_NAME=\"OpenViBE\" -DOV_CMAKE_PATH_BIN=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/bin\" -DOV_CMAKE_PATH_DATA=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/share/openvibe\" -DOV_CMAKE_PATH_LIB=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/lib\" -DOV_CMAKE_PATH_ROOT=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release\" -DOV_CONFIG_SUBDIR=\"openvibe-2.0\" -DOV_DISPLAY_ERROR_LOCATION -DOV_PROJECT_NAME=\"OpenVIBE\" -DOV_VERSION_MAJOR=\"0\" -DOV_VERSION_MINOR=\"0\" -DOV_VERSION_PATCH=\"0\" -DTARGET_ARCHITECTURE_i386 -DTARGET_BUILDTYPE_Release -DTARGET_COMPILER_GCC -DTARGET_OS_Linux  -fopenmp -Wall -msse2 -O3 -DNDEBUG   -fnon-call-exceptions -std=gnu++11 -MMD -MT build-tool/stimulation-generator/CMakeFiles/openvibe-stimulation-generator.dir/src/ovbt_sg_main.cpp.o -MF build-tool/stimulation-generator/CMakeFiles/openvibe-stimulation-generator.dir/src/ovbt_sg_main.cpp.o.d -o build-tool/stimulation-generator/CMakeFiles/openvibe-stimulation-generator.dir/src/ovbt_sg_main.cpp.o -c /home/juan/OpenBCI/openvibe-2.0.1-src/sdk/build-tool/stimulation-generator/src/ovbt_sg_main.cpp
c++: error: unrecognized command line option ‘-msse2’
[6/339] Building CXX object build-tool...r/src/ovbt_sg_cpp_code_generator.cpp.o
FAILED: /usr/bin/c++   -DBRAND_NAME=\"OpenViBE\" -DOV_CMAKE_PATH_BIN=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/bin\" -DOV_CMAKE_PATH_DATA=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/share/openvibe\" -DOV_CMAKE_PATH_LIB=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/lib\" -DOV_CMAKE_PATH_ROOT=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release\" -DOV_CONFIG_SUBDIR=\"openvibe-2.0\" -DOV_DISPLAY_ERROR_LOCATION -DOV_PROJECT_NAME=\"OpenVIBE\" -DOV_VERSION_MAJOR=\"0\" -DOV_VERSION_MINOR=\"0\" -DOV_VERSION_PATCH=\"0\" -DTARGET_ARCHITECTURE_i386 -DTARGET_BUILDTYPE_Release -DTARGET_COMPILER_GCC -DTARGET_OS_Linux  -fopenmp -Wall -msse2 -O3 -DNDEBUG   -fnon-call-exceptions -std=gnu++11 -MMD -MT build-tool/stimulation-generator/CMakeFiles/openvibe-stimulation-generator.dir/src/ovbt_sg_cpp_code_generator.cpp.o -MF build-tool/stimulation-generator/CMakeFiles/openvibe-stimulation-generator.dir/src/ovbt_sg_cpp_code_generator.cpp.o.d -o build-tool/stimulation-generator/CMakeFiles/openvibe-stimulation-generator.dir/src/ovbt_sg_cpp_code_generator.cpp.o -c /home/juan/OpenBCI/openvibe-2.0.1-src/sdk/build-tool/stimulation-generator/src/ovbt_sg_cpp_code_generator.cpp
[6/339] Building CXX object common/CMa...les/openvibe-common.dir/src/main.cpp.o
FAILED: /usr/bin/c++   -DBRAND_NAME=\"OpenViBE\" -DOV_CMAKE_PATH_BIN=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/bin\" -DOV_CMAKE_PATH_DATA=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/share/openvibe\" -DOV_CMAKE_PATH_LIB=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/lib\" -DOV_CMAKE_PATH_ROOT=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release\" -DOV_CONFIG_SUBDIR=\"openvibe-2.0\" -DOV_DISPLAY_ERROR_LOCATION -DOV_PROJECT_NAME=\"OpenVIBE\" -DOV_VERSION_MAJOR=\"0\" -DOV_VERSION_MINOR=\"0\" -DOV_VERSION_PATCH=\"0\" -DTARGET_ARCHITECTURE_i386 -DTARGET_BUILDTYPE_Release -DTARGET_COMPILER_GCC -DTARGET_HAS_Boost -DTARGET_OS_Linux -I/home/juan/OpenBCI/openvibe-2.0.1-src/sdk/common/include -fopenmp -Wall -msse2 -O3 -DNDEBUG   -fnon-call-exceptions -std=gnu++11 -MMD -MT common/CMakeFiles/openvibe-common.dir/src/main.cpp.o -MF common/CMakeFiles/openvibe-common.dir/src/main.cpp.o.d -o common/CMakeFiles/openvibe-common.dir/src/main.cpp.o -c /home/juan/OpenBCI/openvibe-2.0.1-src/sdk/common/src/main.cpp
[6/339] Building CXX object build-tool...src/ovbt_sg_cpp_define_generator.cpp.o
FAILED: /usr/bin/c++   -DBRAND_NAME=\"OpenViBE\" -DOV_CMAKE_PATH_BIN=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/bin\" -DOV_CMAKE_PATH_DATA=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/share/openvibe\" -DOV_CMAKE_PATH_LIB=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/lib\" -DOV_CMAKE_PATH_ROOT=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release\" -DOV_CONFIG_SUBDIR=\"openvibe-2.0\" -DOV_DISPLAY_ERROR_LOCATION -DOV_PROJECT_NAME=\"OpenVIBE\" -DOV_VERSION_MAJOR=\"0\" -DOV_VERSION_MINOR=\"0\" -DOV_VERSION_PATCH=\"0\" -DTARGET_ARCHITECTURE_i386 -DTARGET_BUILDTYPE_Release -DTARGET_COMPILER_GCC -DTARGET_OS_Linux  -fopenmp -Wall -msse2 -O3 -DNDEBUG   -fnon-call-exceptions -std=gnu++11 -MMD -MT build-tool/stimulation-generator/CMakeFiles/openvibe-stimulation-generator.dir/src/ovbt_sg_cpp_define_generator.cpp.o -MF build-tool/stimulation-generator/CMakeFiles/openvibe-stimulation-generator.dir/src/ovbt_sg_cpp_define_generator.cpp.o.d -o build-tool/stimulation-generator/CMakeFiles/openvibe-stimulation-generator.dir/src/ovbt_sg_cpp_define_generator.cpp.o -c /home/juan/OpenBCI/openvibe-2.0.1-src/sdk/build-tool/stimulation-generator/src/ovbt_sg_cpp_define_generator.cpp
[6/339] Building CXX object build-tool...dir/src/ovbt_sg_matlab_generator.cpp.o
FAILED: /usr/bin/c++   -DBRAND_NAME=\"OpenViBE\" -DOV_CMAKE_PATH_BIN=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/bin\" -DOV_CMAKE_PATH_DATA=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/share/openvibe\" -DOV_CMAKE_PATH_LIB=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/lib\" -DOV_CMAKE_PATH_ROOT=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release\" -DOV_CONFIG_SUBDIR=\"openvibe-2.0\" -DOV_DISPLAY_ERROR_LOCATION -DOV_PROJECT_NAME=\"OpenVIBE\" -DOV_VERSION_MAJOR=\"0\" -DOV_VERSION_MINOR=\"0\" -DOV_VERSION_PATCH=\"0\" -DTARGET_ARCHITECTURE_i386 -DTARGET_BUILDTYPE_Release -DTARGET_COMPILER_GCC -DTARGET_OS_Linux  -fopenmp -Wall -msse2 -O3 -DNDEBUG   -fnon-call-exceptions -std=gnu++11 -MMD -MT build-tool/stimulation-generator/CMakeFiles/openvibe-stimulation-generator.dir/src/ovbt_sg_matlab_generator.cpp.o -MF build-tool/stimulation-generator/CMakeFiles/openvibe-stimulation-generator.dir/src/ovbt_sg_matlab_generator.cpp.o.d -o build-tool/stimulation-generator/CMakeFiles/openvibe-stimulation-generator.dir/src/ovbt_sg_matlab_generator.cpp.o -c /home/juan/OpenBCI/openvibe-2.0.1-src/sdk/build-tool/stimulation-generator/src/ovbt_sg_matlab_generator.cpp
[6/339] Building CXX object modules/cs...module-csv-static.dir/src/ovICSV.cpp.o
FAILED: /usr/bin/c++   -DBRAND_NAME=\"OpenViBE\" -DFS_Static -DOV_CMAKE_PATH_BIN=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/bin\" -DOV_CMAKE_PATH_DATA=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/share/openvibe\" -DOV_CMAKE_PATH_LIB=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release/lib\" -DOV_CMAKE_PATH_ROOT=\"/home/juan/OpenBCI/openvibe-2.0.1-src/dist/sdk-Release\" -DOV_CONFIG_SUBDIR=\"openvibe-2.0\" -DOV_DISPLAY_ERROR_LOCATION -DOV_PROJECT_NAME=\"OpenVIBE\" -DOV_VERSION_MAJOR=\"0\" -DOV_VERSION_MINOR=\"0\" -DOV_VERSION_PATCH=\"0\" -DTARGET_ARCHITECTURE_i386 -DTARGET_BUILDTYPE_Release -DTARGET_COMPILER_GCC -DTARGET_HAS_Boost -DTARGET_HAS_FS -DTARGET_HAS_OpenViBE_Common -DTARGET_HAS_ThirdPartyOpenViBEPluginsGlobalDefines -DTARGET_OS_Linux -I/home/juan/OpenBCI/openvibe-2.0.1-src/sdk/modules/csv/include/csv -I/home/juan/OpenBCI/openvibe-2.0.1-src/sdk/common/include -I/home/juan/OpenBCI/openvibe-2.0.1-src/sdk/modules/fs/include -fopenmp -Wall -msse2 -O3 -DNDEBUG   -fnon-call-exceptions -fPIC -std=gnu++11 -MMD -MT modules/csv/CMakeFiles/openvibe-module-csv-static.dir/src/ovICSV.cpp.o -MF modules/csv/CMakeFiles/openvibe-module-csv-static.dir/src/ovICSV.cpp.o.d -o modules/csv/CMakeFiles/openvibe-module-csv-static.dir/src/ovICSV.cpp.o -c /home/juan/OpenBCI/openvibe-2.0.1-src/sdk/modules/csv/src/ovICSV.cpp
ninja: build stopped: subcommand failed.
ERROR: Build failed
Error while building sdk
Re: Error building in raspberry pi3
Posted: Tue Feb 06, 2018 4:53 pm
by jtlindgren
Hi, based on the log you posted, you should investigate the CMakeLists.txt files for lines like
Code: Select all
	# Switch -msse2 enables vectorization. Remove if your CPU/compiler doesn't support it.
	SET(OV_EIGEN_FLAGS "-msse2")
and remove the flag that your compiler does not support.
Note that Raspberry Pi is not an official supported platform so you might have other issues later.
Good luck!
Best,
Jussi
Posted: Wed Feb 07, 2018 2:23 pm
by b0rn4
Thanks!!
Your idea work at the moment, but now build never complete. My raspberry freeze randomly in building process.
I know from guys they run openvibe 1.2.2 in raspberry but doesn't work for me.
If somebody run openvibe successfully in raspberry will be amazing a few tips.!
Thanks!
Posted: Mon Feb 19, 2018 9:18 pm
by b0rn4
I had success in prevent freezing my pi3 limiting the number of "jobs" in building process, temperature is okey and building appears doing fine until this error at 22%.
Can someone suggest a solution for this?
Cheers.
Code: Select all
[ 22%] Building CXX object toolkit/CMakeFiles/openvibe-toolkit.dir/src/tools/ovtkMatrix.cpp.o
/home/pi/OpenViBE/openvibe-1.2.2-src/toolkit/src/tools/ovtkMatrix.cpp: In function ‘OpenViBE::boolean OpenViBEToolkit::Tools::Matrix::isContentValid(const OpenViBE::IMatrix&, OpenViBE::boolean, OpenViBE::boolean)’:
/home/pi/OpenViBE/openvibe-1.2.2-src/toolkit/src/tools/ovtkMatrix.cpp:162:42: error: ‘isnan’ was not declared in this scope
   if(bCheckNotANumber && isnan(*l_pBuffer)) return false;
/home/pi/OpenViBE/openvibe-1.2.2-src/toolkit/src/tools/ovtkMatrix.cpp:162:42: note: suggested alternative:
In file included from /home/pi/OpenViBE/openvibe-1.2.2-src/toolkit/src/tools/ovtkMatrix.cpp:6:0:
/usr/include/c++/6/cmath:662:5: note:   ‘std::isnan’
     isnan(_Tp __x)
/home/pi/OpenViBE/openvibe-1.2.2-src/toolkit/src/tools/ovtkMatrix.cpp:163:40: error: ‘isinf’ was not declared in this scope
   if(bCheckInfinity && isinf(*l_pBuffer)) return false;
/home/pi/OpenViBE/openvibe-1.2.2-src/toolkit/src/tools/ovtkMatrix.cpp:163:40: note: suggested alternative:
/usr/include/c++/6/cmath:635:5: note:   ‘std::isinf’
     isinf(_Tp __x)
toolkit/CMakeFiles/openvibe-toolkit.dir/build.make:262: recipe for target 'toolkit/CMakeFiles/openvibe-toolkit.dir/src/tools/ovtkMatrix.cpp.o' failed
make[2]: *** [toolkit/CMakeFiles/openvibe-toolkit.dir/src/tools/ovtkMatrix.cpp.o] Error 1
CMakeFiles/Makefile2:980: recipe for target 'toolkit/CMakeFiles/openvibe-toolkit.dir/all' failed
make[1]: *** [toolkit/CMakeFiles/openvibe-toolkit.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
