i run into the following when running build.sh:
Building sdk
./build.sh: line 54: ./unix-build: Permission denied
Error while building sdk
even though i have changed ownership of the root and all sub directories using "sudo chown -R pi:pi openvibe-2.0.0-src"
and ..also tried running it in root mode using "sudo su"
any help would be appreciated a lot!
thanks
building on Raspberry Pi
Re: building on Raspberry Pi
This might be a bit silly question, but does the file
openvibe-2.0.0-src/sdk/scripts/unix-build
have the "x" flag set for o and g? Is your current account "pi" that you launch the script with?
