OpenVibe 2.0 Build fails on LPTHREADS
coristus
Post by coristus »
Hello all,
I tried searching for this problem everywhere online, and all i could find was that i need to install the lptrhead library, which I superfluously did (it was already installed)
I am running on Ubuntu 16.04.1 without plymouth (videocard issues) and Gnome desktop I followed the instructions and installed dependencies first.. everything was ok but at the end of the build it failed. I tried removing the build and tried again after update and upgrade... same exact error. Am I missing something obvious or is something wrong with either my ubuntu or with the build?
CMakeError.log:
Determining if the pthread_create exist failed with the following output:
Change Dir: /home/coristus/Downloads/openvibe-2.0.0-src/build/sdk-Release/CMakeFiles/CMakeTmp
Run Build Command:"/usr/bin/ninja" "cmTC_dbe9b"
[1/2] Building C object CMakeFiles/cmTC_dbe9b.dir/CheckSymbolExists.c.o
[2/2] Linking C executable cmTC_dbe9b
FAILED: : && /usr/bin/cc CMakeFiles/cmTC_dbe9b.dir/CheckSymbolExists.c.o -o cmTC_dbe9b && :
CMakeFiles/cmTC_dbe9b.dir/CheckSymbolExists.c.o: In function `main':
CheckSymbolExists.c:(.text+0x16): undefined reference to `pthread_create'
ninja: build stopped: subcommand failed.
File /home/coristus/Downloads/openvibe-2.0.0-src/build/sdk-Release/CMakeFiles/CMakeTmp/CheckSymbolExists.c:
#include <pthread.h>
int main(int argc, char** argv)
(void)argv;
#ifndef pthread_create
return ((int*)(&pthread_create))[argc];
#else
(void)argc;
return 0;
#endif
Determining if the function pthread_create exists in the pthreads failed with the following output:
Run Build Command:"/usr/bin/ninja" "cmTC_ecd45"
[1/2] Building C object CMakeFiles/cmTC_ecd45.dir/CheckFunctionExists.c.o
[2/2] Linking C executable cmTC_ecd45
FAILED: : && /usr/bin/cc -DCHECK_FUNCTION_EXISTS=pthread_create CMakeFiles/cmTC_ecd45.dir/CheckFunctionExists.c.o -o cmTC_ecd45 -lpthreads && :
/usr/bin/ld: cannot find -lpthreads
tgaugry
Re: OpenVibe 2.0 Build fails on LPTHREADS
Post by tgaugry »
Did you follow the process described in http://openvibe.inria.fr/build-instruct ... g+on+Linux ?
Can you give us the output of the build.sh command ? (remove dist and build folders, and relaunch it)
coristus
Post by coristus »
Hi tgaugry,
Thank you for your reply.
Yes, I follow the instructions to the letter.. And I also removed and repeated the install as you suggest, with the exact same result. Which output would you like? The posted text is the exact text from the CMakeError.log generated by build.sh. Do you want the full log as well? or just the console output?
tgaugry
Post by tgaugry »
Without the console output, i can't do much.
Can you post it here (in a file) ?
coristus
Post by coristus »
No problem, when i get home tonight I'll get on it
Thanks .
Ok just deleted the dist and build directories.. reran build to and this is the result:
I replaced the physical home path with ~, in the actual file it is the real path.
File attached :)
build.txt
(11.41 KiB) Downloaded 198 times
tgaugry
Post by tgaugry »
that's strange, to say the least !
We have a CI machine running ubuntu 16.04 which has no problem building the software.
Do you have the same values for the 2 following commands ?
ci@ubuntu1604:~$ uname -a
Linux ubuntu1604 4.4.0-96-generic #119-Ubuntu SMP Tue Sep 12 14:59:54 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
ci@ubuntu1604:~$ apt list --installed | grep thread
libboost-thread-dev/xenial,now 1.58.0.1ubuntu1 amd64 [installed]
libboost-thread1.58-dev/xenial-updates,now 1.58.0+dfsg-5ubuntu3.1 amd64 [installed,automatic]
libboost-thread1.58.0/xenial-updates,now 1.58.0+dfsg-5ubuntu3.1 amd64 [installed,automatic]
libpthread-stubs0-dev/xenial,now 0.3-4 amd64 [installed,automatic]
