Output is the same even though changes have been made
User
Post by User »
I've tried to accomplish what was suggested in viewtopic.php?f=3&t=329&p=1518&hilit=random+flash#p1518
However, I couldn't see any changes in the flash sequence even though that I rebuilt the project.
Do you have an idea why is this happening?
Thank you, any help is deeply appreciated.
Re: Output is the same even though changes have been made
Hi, make sure that whatever you're running, is using the changed resources. For example, if you compile your stuff yourself, all the stuff is in dist/. However, if you run Designer from Program Files/, it will take all the old resources from under Program Files, not your newly built ones. In the case you build yourself, launch designer that has been built from dist/. Check that 'make install' or building the install target has resulted in the modified, rebuilt stuff actually being there somewhere under dist/ as should be (instead of the old files).
User
Post by User »
Thank you for the reply.
This is the way how I open it. Unfortunately, I didn't notice any changes.
Any suggestions?
