OpenVibe on Opensuse
thakou
Post by thakou »
I've tried to compiled the program on my PC with Opensuse Tumbleweed and I had no luck so far. Is there anyone that has accomplished such installation and could share any of his/her experiences? My attempt on a Ubuntu 16.04 system (in Virtual Box) was easily successful, but due to the fact that our lab PCs have Opensuse installed I would like to make openvibe run on this configuration.
Any help would be appreciated,
TIA
Re: OpenVibe on Opensuse
Hi Thakou,
sorry for the late reply -- basically the only thing I can think of is just to try to compile the thing and then address the errors one by one. I expect most of the problems are related to having the compatible versions of the dependencies installed (see scrips/linux-install-dependencies) and if those are not available for Opensuse, get the closest corresponding version, fix OpenViBE to compile with that, and/or disable the corresponding part in OpenViBE if possible.
