It is currently Mon Feb 18, 2019 2:39 am
PostPosted: Tue May 24, 2016 3:41 am
I've tried to compile the code after following all the steps illustrated in the manual. However, the building was never completed.
OS: windows 8
VS: 2010
The log:
Code:
[ 72%] Built target openvibe-examples-openvibe-to-vrpn
[ 73%] Built target openvibe-examples-vrpn-to-openvibe
Linking CXX executable openvibe-acquisition-server.exe
LINK : warning LNK4199: /DELAYLOAD:edk.dll ignored; no imports found from edk.dl
l
ovasCDriverEmotivEPOC.cpp.obj : error LNK2019: unresolved external symbol __imp_
_EE_EmoEngineEventFree referenced in function "public: virtual bool __thiscall O
penViBEAcquisitionServer::CDriverEmotivEPOC::uninitialize(void)" (?uninitialize@
CDriverEmotivEPOC@OpenViBEAcquisitionServer@@UAE_NXZ)
_EE_EngineDisconnect referenced in function "public: virtual bool __thiscall Ope
nViBEAcquisitionServer::CDriverEmotivEPOC::uninitialize(void)" (?uninitialize@CD
_EE_EngineConnect referenced in function "public: virtual bool __thiscall OpenVi
BEAcquisitionServer::CDriverEmotivEPOC::initialize(unsigned int,class OpenViBEAc
quisitionServer::IDriverCallback &)" (?initialize@CDriverEmotivEPOC@OpenViBEAcqu
isitionServer@@UAE_NIAAVIDriverCallback@2@@Z)
_EE_EmoEngineEventCreate referenced in function "public: virtual bool __thiscall
 OpenViBEAcquisitionServer::CDriverEmotivEPOC::initialize(unsigned int,class Ope
nViBEAcquisitionServer::IDriverCallback &)" (?initialize@CDriverEmotivEPOC@OpenV
iBEAcquisitionServer@@UAE_NIAAVIDriverCallback@2@@Z)
_EE_DataSetBufferSizeInSec referenced in function "public: virtual bool __thisca
ll OpenViBEAcquisitionServer::CDriverEmotivEPOC::start(void)" (?start@CDriverEmo
_EE_DataCreate referenced in function "public: virtual bool __thiscall OpenViBEA
cquisitionServer::CDriverEmotivEPOC::start(void)" (?start@CDriverEmotivEPOC@Open
_EE_DataGet referenced in function "public: virtual bool __thiscall OpenViBEAcqu
isitionServer::CDriverEmotivEPOC::loop(void)" (?loop@CDriverEmotivEPOC@OpenViBEA
_EE_DataGetNumberOfSample referenced in function "public: virtual bool __thiscal
l OpenViBEAcquisitionServer::CDriverEmotivEPOC::loop(void)" (?loop@CDriverEmotiv
_EE_DataUpdateHandle referenced in function "public: virtual bool __thiscall Ope
nViBEAcquisitionServer::CDriverEmotivEPOC::loop(void)" (?loop@CDriverEmotivEPOC@
_EE_DataAcquisitionEnable referenced in function "public: virtual bool __thiscal
_EE_EmoEngineEventGetUserId referenced in function "public: virtual bool __thisc
all OpenViBEAcquisitionServer::CDriverEmotivEPOC::loop(void)" (?loop@CDriverEmot
_EE_EmoEngineEventGetType referenced in function "public: virtual bool __thiscal
_EE_EngineGetNextEvent referenced in function "public: virtual bool __thiscall O
penViBEAcquisitionServer::CDriverEmotivEPOC::loop(void)" (?loop@CDriverEmotivEPO
_EE_DataFree referenced in function "public: virtual bool __thiscall OpenViBEAcq
uisitionServer::CDriverEmotivEPOC::stop(void)" (?stop@CDriverEmotivEPOC@OpenViBE
ovasCAcquisitionServerGUI.cpp.obj : error LNK2019: unresolved external symbol "p
ublic: __thiscall OpenViBEAcquisitionServer::CDriverTMSiRefa32B::CDriverTMSiRefa
32B(class OpenViBEAcquisitionServer::IDriverContext &)" (??0CDriverTMSiRefa32B@O
penViBEAcquisitionServer@@QAE@AAVIDriverContext@1@@Z) referenced in function "pu
blic: __thiscall OpenViBEAcquisitionServer::CAcquisitionServerGUI::CAcquisitionS
erverGUI(class OpenViBE::Kernel::IKernelContext const &)" (??0CAcquisitionServer
GUI@OpenViBEAcquisitionServer@@QAE@ABVIKernelContext@Kernel@OpenViBE@@@Z)
openvibe-acquisition-server.exe : fatal error LNK1120: 15 unresolved externals
LINK failed. with 2
NMAKE : fatal error U1077: 'C:\Users\Y\Desktop\openvibe-1.2.0-src\dep
endencies\cmake\bin\cmake.exe' : return code '0xffffffff'
Stop.
NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual Studio 10.0
\VC\BIN\nmake.exe"' : return code '0x2'
Stop.
Stop.
any one might know how can this be solved?
PostPosted: Mon May 30, 2016 6:44 am
Hi, it looks like there's some problem compiling the emotiv driver. One option is to disable the detection of that driver from the FindThirdPartyEmotiv-script, or if the os-level driver version you have installed is unsupported, you can downgrade it, uninstall it, or fix the openvibe side of the driver.
We're not currently looking into it at the core team though. Our access to the newer emotiv drivers is "rather limited", the main reason why Openvibe emotiv support is for an older version.
PostPosted: Fri Jun 24, 2016 2:16 am
I used another OS - Windows 7- and it worked just fine.
Thank you for the reply.
cron
