It is currently Tue May 22, 2018 12:06 pm
PostPosted: Fri Jan 09, 2015 4:21 pm
hi i´m having problem intalling the 0.18.0 in debian and ubuntu and we have the same error.
In file included from /usr/include/gdk/gdk.h:32:0,
from /usr/include/gtk/gtk.h:32,
from /home/edison/open/applications/developer-tools/vrpn-simulator/src/ova_main.cpp:3:
/usr/include/gdk/gdkapplaunchcontext.h:30:21: fatal error: gio/gio.h: No such file or directory
compilation terminated.
I try to clean and rebuild and we have the same problem. I have some problem that the make is searching the files in wrongs folders.
I usually change the adress and goes, but in this time i cant fixed.
PostPosted: Mon Jan 12, 2015 8:51 am
Somebody has had similar problem before, although with VS.
http://stackoverflow.com/questions/4699 ... -directory
Do you have the header it complains about in a reasonable, normal place?
J.
PostPosted: Tue Jan 13, 2015 9:45 am
I solved the problem with a very bad solution. I must to feinstall ubunru or debian and in the start install openvibe, because its a problem with direction of folders
Americanized by Maël Soucaze.
