Installing openvibe in a debian
LUISMAN
Post by LUISMAN »
Im trying to install in a debian the openvibe
I used this repositorie
wget -O- http://neuro.debian.net/lists/wheezy.de-m.full | sudo tee /etc/apt/sources.list.d/neurodebian.sources.list
sudo apt-key adv --recv-keys --keyserver hkp://pgp.mit.edu:80 2649A5A9
from
http://neuro.debian.net/install_pkg.html?p=openvibe-bin
and install me
root@ubilinux:~# OpenViBE-
OpenViBE-acquisition-server-dynamic OpenViBE-plugin-inspector-dynamic
OpenViBE-designer-dynamic OpenViBE-skeleton-generator-dynamic
OpenViBE-id-generator-dynamic
When i try the acquisition server give-me this error:
root@ubilinux:~# OpenViBE-acquisition-server-dynamic
[ FAILED ] Error loading kernel (/usr/lib/libOpenViBE-kernel-dynamic.so: cannot open shared object file: No such file or directory)
What i´m doing wrong??
I solved with a simbolic link
ln -s /usr/lib/libOpenViBE-kernel-dynamic.so.0 /usr/lib/libOpenViBE-kernel-dynamic.so
Re: Installing openvibe in a debian
Hi Luisman, if you're using the neurodebian version, I recommend contacting the package maintainer directly.
BTW, based on the names of the files, the OpenViBE version in NeuroDebian appears rather old.
