OpenViBE forum
The OpenViBE community
It is currently Mon Oct 15, 2018 11:35 am
Post new topic Reply to topic  [ 7 posts ]
Author Message
PostPosted: Thu Dec 18, 2014 10:03 am
Offline
Hi
DISCLAIMER: I know less than nothing about c or c++
I am getting the error listed below when building (git source), and from googling I suspect that the links listed has the answer but it is beyond my skill set to fix it seams, could some one please assist me?
http://stackoverflow.com/questions/2033 ... or-message
http://fedoraproject.org/wiki/Understan ... LinkChange
Linking CXX executable test_evidenceaccumulation
CMakeFiles/test_evidenceaccumulation.dir/__/__/src/tagging/ovexCSoftTagger.cpp.o: In function `boost::interprocess::shared_memory_object::remove(char const*)':
/usr/include/boost/interprocess/shared_memory_object.hpp:382: undefined reference to `shm_unlink'
CMakeFiles/test_evidenceaccumulation.dir/__/__/src/tagging/ovexCSoftTagger.cpp.o: In function `boost::interprocess::shared_memory_object::priv_open_or_create(boost::interprocess::ipcdetail::create_enum_t, char const*, boost::interprocess::mode_t, boost::interprocess::permissions const&)':
/usr/include/boost/interprocess/shared_memory_object.hpp:315: undefined reference to `shm_open'
/usr/include/boost/interprocess/shared_memory_object.hpp:309: undefined reference to `shm_open'
CMakeFiles/test_evidenceaccumulation.dir/__/__/src/iocommunication/ovexISharedMemoryReader.cpp.o: In function `boost::interprocess::shared_memory_object::remove(char const*)':
CMakeFiles/test_evidenceaccumulation.dir/__/__/src/iocommunication/ovexISharedMemoryReader.cpp.o: In function `boost::interprocess::shared_memory_object::priv_open_or_create(boost::interprocess::ipcdetail::create_enum_t, char const*, boost::interprocess::mode_t, boost::interprocess::permissions const&)':
/usr/include/boost/interprocess/shared_memory_object.hpp:334: undefined reference to `shm_open'
/usr/include/boost/interprocess/shared_memory_object.hpp:327: undefined reference to `shm_open'
collect2: error: ld returned 1 exit status
contrib/applications/platform/P300Stimulator/test/test_evidenceAccumulation/CMakeFiles/test_evidenceaccumulation.dir/build.make:1061: recipe for target 'contrib/applications/platform/P300Stimulator/test/test_evidenceAccumulation/test_evidenceaccumulation' failed
make[2]: *** [contrib/applications/platform/P300Stimulator/test/test_evidenceAccumulation/test_evidenceaccumulation] Error 1
CMakeFiles/Makefile2:3092: recipe for target 'contrib/applications/platform/P300Stimulator/test/test_evidenceAccumulation/CMakeFiles/test_evidenceaccumulation.dir/all' failed
make[1]: *** [contrib/applications/platform/P300Stimulator/test/test_evidenceAccumulation/CMakeFiles/test_evidenceaccumulation.dir/all] Error 2
Makefile:113: recipe for target 'all' failed
make: *** [all] Error 2
Top
 Profile
PostPosted: Mon Jan 05, 2015 9:05 am
Offline
This likely corresponds to a reported bug,
http://openvibe.inria.fr/tracker/view.php?id=165
We are working on it.
Best,
Jussi
Top
 Profile
PostPosted: Mon Jan 12, 2015 12:45 pm
Offline
Thanx it looks that way, I will keep an eye on the tracker issue.
Let me know if there is anything I can help with, even if it is just testing.
Top
 Profile
PostPosted: Mon Jan 12, 2015 12:47 pm
Offline
Hi Harag,
the problem should now be fixed in git master, you could try to compile that and let us know if it worked for you.
Thanks,
Jussi
Top
 Profile
PostPosted: Fri Jan 16, 2015 8:56 am
Offline
Hi
Its compiling without any errors thanx, I will test with my device tonight I don't have it on hand at the moment.
Regards
Phil
Top
 Profile
PostPosted: Mon Jan 19, 2015 10:10 am
Offline
So all works well untill I add a temporal filter, the designer crashes out if I run a scenario with a temporal filter in it.
This is the error i see in the terminal:
/openvibe/dist/bin/openvibe-designer: symbol lookup error: /home/phil/Development/openvibe/dist/lib/x86_64-linux-gnu/libopenvibe-plugins-contrib-signal-processing.so: undefined symbol: _ZN4itpp5zerosEi
Should I create a new issue for this?
Would compiling with --debug give more info?
Top
 Profile
PostPosted: Sat Jan 24, 2015 10:10 am
Offline
Logged a bug report, with relevant files for the designer crash.
http://openvibe.inria.fr/tracker/view.php?id=167
Top
 Profile
Who is online
Users browsing this forum: No registered users and 3 guests
Search for:
Jump to:
Americanized by Maƫl Soucaze.
