Build on Ubuntu 14.10 fails -undefined reference to shm_open
Harag
Post by Harag »
Hi
DISCLAIMER: I know less than nothing about c or c++
I am getting the error listed below when building (git source), and from googling I suspect that the links listed has the answer but it is beyond my skill set to fix it seams, could some one please assist me?
http://stackoverflow.com/questions/2033 ... or-message
http://fedoraproject.org/wiki/Understan ... LinkChange
Linking CXX executable test_evidenceaccumulation
CMakeFiles/test_evidenceaccumulation.dir/__/__/src/tagging/ovexCSoftTagger.cpp.o: In function `boost::interprocess::shared_memory_object::remove(char const*)':
/usr/include/boost/interprocess/shared_memory_object.hpp:382: undefined reference to `shm_unlink'
CMakeFiles/test_evidenceaccumulation.dir/__/__/src/tagging/ovexCSoftTagger.cpp.o: In function `boost::interprocess::shared_memory_object::priv_open_or_create(boost::interprocess::ipcdetail::create_enum_t, char const*, boost::interprocess::mode_t, boost::interprocess::permissions const&)':
/usr/include/boost/interprocess/shared_memory_object.hpp:315: undefined reference to `shm_open'
/usr/include/boost/interprocess/shared_memory_object.hpp:309: undefined reference to `shm_open'
CMakeFiles/test_evidenceaccumulation.dir/__/__/src/iocommunication/ovexISharedMemoryReader.cpp.o: In function `boost::interprocess::shared_memory_object::remove(char const*)':
CMakeFiles/test_evidenceaccumulation.dir/__/__/src/iocommunication/ovexISharedMemoryReader.cpp.o: In function `boost::interprocess::shared_memory_object::priv_open_or_create(boost::interprocess::ipcdetail::create_enum_t, char const*, boost::interprocess::mode_t, boost::interprocess::permissions const&)':
/usr/include/boost/interprocess/shared_memory_object.hpp:334: undefined reference to `shm_open'
/usr/include/boost/interprocess/shared_memory_object.hpp:327: undefined reference to `shm_open'
contrib/applications/platform/P300Stimulator/test/test_evidenceAccumulation/CMakeFiles/test_evidenceaccumulation.dir/build.make:1061: recipe for target 'contrib/applications/platform/P300Stimulator/test/test_evidenceAccumulation/test_evidenceaccumulation' failed
make[2]: *** [contrib/applications/platform/P300Stimulator/test/test_evidenceAccumulation/test_evidenceaccumulation] Error 1
CMakeFiles/Makefile2:3092: recipe for target 'contrib/applications/platform/P300Stimulator/test/test_evidenceAccumulation/CMakeFiles/test_evidenceaccumulation.dir/all' failed
make[1]: *** [contrib/applications/platform/P300Stimulator/test/test_evidenceAccumulation/CMakeFiles/test_evidenceaccumulation.dir/all] Error 2
Makefile:113: recipe for target 'all' failed
make: *** [all] Error 2
Re: Build on Ubuntu 14.10 fails -undefined reference to shm_
This likely corresponds to a reported bug,
http://openvibe.inria.fr/tracker/view.php?id=165
We are working on it.
Harag
Post by Harag »
Thanx it looks that way, I will keep an eye on the tracker issue.
Let me know if there is anything I can help with, even if it is just testing.
Hi Harag,
the problem should now be fixed in git master, you could try to compile that and let us know if it worked for you.
Harag
Post by Harag »
Hi
Its compiling without any errors thanx, I will test with my device tonight I don't have it on hand at the moment.
Phil
Harag
Post by Harag »
So all works well untill I add a temporal filter, the designer crashes out if I run a scenario with a temporal filter in it.
This is the error i see in the terminal:
/openvibe/dist/bin/openvibe-designer: symbol lookup error: /home/phil/Development/openvibe/dist/lib/x86_64-linux-gnu/libopenvibe-plugins-contrib-signal-processing.so: undefined symbol: _ZN4itpp5zerosEi
Should I create a new issue for this?
Would compiling with --debug give more info?
Harag
Post by Harag »
Logged a bug report, with relevant files for the designer crash.
http://openvibe.inria.fr/tracker/view.php?id=167
