"Time based epoching" developed code
ammaia
Post by ammaia »
To understand clearly the process inside each modules (for example: "Time based epoching") is it possible to read the developed code?
Pedro
Re: "Time based epoching" developed code
You can download the OpenViBE source code archive from the download page. With a bit of digging into the folder structure, you should find the code of the box you're interested in. Usually the box name or something very much like it is part of the code filename.
The box you mention is in './plugins/processing/signal-processing/src/box-algorithms/ovpCTimeBasedEpoching.cpp' (+ the corresp. .h file)
