compiling requirements
barten6
Post by barten6 »
is it true that compiling the OV-source code requires a matlab license?
Peter
Re: compiling requirements
No. Matlab is only needed to compile the Matlab plugin. And if you have Matlab installed, it may be possible to compile the plugin even without the Matlab license. However, using the Matlab plugin will require the license.
