It is currently Sun Jul 15, 2018 7:03 pm
 Post subject: Build on Ubuntu14.04
PostPosted: Tue May 13, 2014 11:51 am
Hello everyone,
I just start a new internship and I need tu install openvibe on ubuntu14.04.
First I couldn't install the depedencies with "linux-install_dependencies" beceause libogre-dev was obsolete.
I installed with "apt-get install libogre-1.8-dev" the new library
But now I still can't build the software. There is trouble with the boost library. It can't find a path for boost_system-mt, boost_system_regex...
I had these errors. I'm a beginner with Unix... Thanks for your help.
Code:
../libopenvibe-module-fs.so.0.17.1: référence indéfinie vers « boost::filesystem::path::parent_path() const »
../libopenvibe-module-fs.so.0.17.1: référence indéfinie vers « boost::system::system_category() »
../libopenvibe-module-fs.so.0.17.1: référence indéfinie vers « boost::filesystem::detail::create_directories(boost::filesystem::path const&, boost::system::error_code*) »
../libopenvibe-module-fs.so.0.17.1: référence indéfinie vers « boost::system::generic_category() »
make[2]: *** [modules/fs/test/test_fs] Erreur 1
make[1]: *** [modules/fs/test/CMakeFiles/test_fs.dir/all] Erreur 2
 Post subject: Re: Build on Ubuntu14.04
PostPosted: Tue May 13, 2014 12:57 pm
Hello yneveu,
You do not mention which version of openvibe you are trying. The last release version 0.17 might not compile. However, there are changes in the git version, and that should already work on 14.04 without having to install any packages by hand. The dependency script should do everything.
If you haven't already, please give the git version a try.
Good luck,
PostPosted: Tue May 13, 2014 4:30 pm
This is the 0.17.1 version.
When I try to build, it can't find some libraries from boost. (boost_thread-mt, boost_filesystem-mt...)
I change the CMake files and now it search (boost_thread and boost_file_system) instead of (boost_thread-mt...)
Before he stoped at 7% now he's still building.
I will give you more information if that works entirely.
PostPosted: Wed May 14, 2014 12:07 pm
install completed. There is no '-mt' in the name of the library. This is maybe an explanation
http://stackoverflow.com/questions/3031 ... -thread-mt
PostPosted: Wed May 14, 2014 2:07 pm
Thanks for the report! Our git version has been modified to alternatively look for the libs without the postfixes.
Hope it works for you now.
Americanized by Maël Soucaze.
