It is currently Sun Aug 18, 2019 7:30 am
Post new topic Reply to topic  [ 6 posts ]
PostPosted: Thu Jan 16, 2014 4:47 pm
I'm learning OpenViBE and I wanted to do a motor-imagery scenario with my own visualization. I took a "motor-imagery-bci-3-online.xml" scenario from: http://openvibe.inria.fr/motor-imagery-bci/ but instaed of "Graz visualization" at the end I've connected "Simple DSP" with "Analog VRPN Server" (print screen in the attachment).
Basing on a: http://openvibe.inria.fr/vrpn-tutorial- ... plication/ I've built my own c++ application. Everything works fine except I do not how to read data that is sent to my application. In you tutorial you have a function:
Code:
void VRPN_CALLBACK vrpn_analog_callback(void* user_data, vrpn_ANALOGCB analog)
    for (int i = 0; i < analog.num_channel; i++)
        std::cout << "Analog Channel : " << i << " / Analog Value : " << analog.channel[i] << std::endl;
and it displays data from "Sinus oscillator". Could you tell me how can I read the data (structure) that comes to my app?
File comment: My scenario
PostPosted: Fri Jan 17, 2014 9:07 am
Hi Pwierzgala,
does the tutorial work as expected? If so, you should be similarly able to read the raw data from analog.channel array, as in the code snippet.
PostPosted: Fri Jan 17, 2014 10:06 am
Wow, it's amazing :) I've spent the whole evening reading documentation, source code and experimenting with my own code with no result. For all that time function "vrpn_analog_callback" was executed but not the code from the loop:
Code:
And now I ran the app again and here's my output:
Code:
Analog Channel : 0 / Analog Value : -1.22847
Well, thanks for help (magic) :)
PostPosted: Sat Jan 18, 2014 3:11 pm
I need to resume this topic. After succeed with "acquisition client" (generic oscillator) I wanted to test it with some real signal. I have to this this scenarion before connecting with eeg device. I've replaced "acquisition client" with "csv reader" but it doesen't work. The "vrpn_analog_callback" function is not executed.
I have no errors in OpenViBE log but I get the following message from my c++ app:
Code:
 VRPN Warning
 (3) from openvibe_analog_vrpn_server: No response from server for >= 3 seconds
I attach sample of my csv file a print screen of my current secenario.
sig.csv [244.85 KiB]
Downloaded 224 times
PostPosted: Mon Jan 20, 2014 9:15 am
Try adding 'signal display' and/or 'EBML spy' to various points of the processing chain to see if valid data is coming out. For example, the CSV reader is very picky about its input format and may not be outputting anything.
PostPosted: Mon Jan 20, 2014 3:59 pm
Thanks for the hint! I've found that when I use "CSV file reader" nothing comes out of "time based epoching" box. Do you have any idea why? Maybe there's something wrong with my csv file format. Are there any requirements about it? I've read those boxes documentation but I haven't found anything helpful there.
cron
