It is currently Mon Jul 16, 2018 10:14 pm
 Post subject: Raspberry Pi (Raspbian)
PostPosted: Fri Nov 29, 2013 5:21 pm
Hi everybody,
I just succeed in compiling OpenVibes on a raspberry pi (rasbian distribution).
As I only plan to use the Acquisition Server on the Rasp, I do not test the designer, but everything was compiled so ...
In fact, the solution is really simple : just modify the linux-install-dependencies script in the check distribution part :
Code:
        if [[ "`grep -E 'Ubuntu|LinuxMint' /etc/lsb-release 2> /dev/null`" != "" ]]; then
must become
Code:
        if [[ "`grep -E 'Ubuntu|LinuxMint|Raspbian' /etc/os-release 2> /dev/null`" != "" ]]; then
Note that on raspbian distribu, there is no lsb-release but an os-release file.
It seems that every needed package is available for the raspbian distribution, so nothing more to do, except compiling with linux-build script
The only strange behaviour is that the compilation process randomly fails, so you have to launch the build script many times to obtain the final product :shock:
DrMick
PostPosted: Fri Dec 06, 2013 9:58 am
That's great news! Except the build crashes of course. We haven't tried raspbian here. Just a guess - could it be running out of memory?
I changed the dependency installer on git to check for Raspbian. Note that its still not an officially supported platform, but if it works, great. :)
Thank you for the tip!
PostPosted: Sun Sep 21, 2014 8:31 am
I have tried compiling openvibe on a raspberry pi (raspbian) without success.
This is with a new install of Rasbian. Errors are post below.
Has anyone who has managed to do this come across similar problems?
Any advice?
I would really appreciate any help.
James
Errors:
when i run ./linux-install_dependencies i get this error:
The Xf86VidMode library and headers were not found
and when i run ./linux-build i get:
/home/pi/Desktop/openvibe/common/src/main.cpp: In function ‘int main()’:
/home/pi/Desktop/openvibe/common/src/main.cpp:35:2: error: invalid application of ‘sizeof’ to incomplete type ‘boost::STATIC_ASSERTION_FAILURE<false>’
/home/pi/Desktop/openvibe/common/src/main.cpp:35:2: error: template argument 1 is invalid
/home/pi/Desktop/openvibe/common/src/main.cpp:35:55: error: invalid type in declaration before ‘;’ token
common/CMakeFiles/openvibe-common.dir/build.make:54: recipe for target 'common/CMakeFiles/openvibe-common.dir/src/main.cpp.o' failed
make[2]: *** [common/CMakeFiles/openvibe-common.dir/src/main.cpp.o] Error 1
CMakeFiles/Makefile2:75: recipe for target 'common/CMakeFiles/openvibe-common.dir/all' failed
make[1]: *** [common/CMakeFiles/openvibe-common.dir/all] Error 2
Makefile:113: recipe for target 'all' failed
make: *** [all] Error 2
PostPosted: Tue Sep 23, 2014 7:19 am
Hi James,
please google for the package in your distro that gives you the Xf86VidMode lib and headers.
About the compilation error, if you look at the code in question it seems that there could be an
issue with float80. Possibly that is not available on your platform. This type is not widely used in
the openvibe code. You could try to remove the tests that cause the error and add a hack
#define float80 float64
instead.
PostPosted: Tue Sep 30, 2014 12:38 pm
I confirm I was able to build the acquisition-server and kernel module by applying the attached patch
File comment: Patch to be unzipped and applied in openvibe directory
raspberry.zip [752 Bytes]
Downloaded 297 times
Users browsing this forum: No registered users and 4 guests
Americanized by Maël Soucaze.
