Raspberry Pi (Raspbian)
Posted: Fri Nov 29, 2013 5:21 pm
Hi everybody,
I just succeed in compiling OpenVibes on a raspberry pi (rasbian distribution).
As I only plan to use the Acquisition Server on the Rasp, I do not test the designer, but everything was compiled so ...
In fact, the solution is really simple : just modify the linux-install-dependencies script in the check distribution part :
must become
Note that on raspbian distribu, there is no lsb-release but an os-release file.
It seems that every needed package is available for the raspbian distribution, so nothing more to do, except compiling with linux-build script
The only strange behaviour is that the compilation process randomly fails, so you have to launch the build script many times to obtain the final product
DrMick
Code: Select all
if [[ "`grep -E 'Ubuntu|LinuxMint' /etc/lsb-release 2> /dev/null`" != "" ]]; then
Code: Select all
if [[ "`grep -E 'Ubuntu|LinuxMint|Raspbian' /etc/os-release 2> /dev/null`" != "" ]]; then
DrMick
