It is currently Wed Jun 19, 2013 11:18 am
PostPosted: Fri May 18, 2012 6:03 am
Hi,,,
Can someone help me to check this problem?
I downloaded the latest stable version Openvibe 0.13.1. I am using VS2010.
When i want to bulid this openvibe, it always show me the following error. I have uninstalled the previours version of CMake. And also re-running the Win32-clean. Still the problem occurs.
Can someone one give me some suggestion to fix this one?
Thank you very much.
Code:
 to prevent data loss
e:\ncl_eeg\openvibe\openvibe-0.13.1-svn3210-src\openvibe\trunc\include\openvibe\
plugins/ovIAlgorithm.h : warning C4819: The file contains a character that canno
t be represented in the current code page (936). Save the file in Unicode format
plugins\ovIPluginObject.h : warning C4819: The file contains a character that ca
nnot be represented in the current code page (936). Save the file in Unicode for
mat to prevent data loss
plugins/ovIAlgorithmDesc.h : warning C4819: The file contains a character that c
annot be represented in the current code page (936). Save the file in Unicode fo
rmat to prevent data loss
plugins\ovIPluginObjectDesc.h : warning C4819: The file contains a character tha
t cannot be represented in the current code page (936). Save the file in Unicode
 format to prevent data loss
plugins/ovIBoxAlgorithm.h : warning C4819: The file contains a character that ca
plugins/ovIBoxAlgorithmDesc.h : warning C4819: The file contains a character tha
[100%] Building CXX object CMakeFiles/OpenViBE-acquisition-server-dynamic.dir/sr
c/tmsi-refa32b/ovasCDriverTMSiRefa32B.obj
cl : Command line warning D9002 : ignoring unknown option '-mms-bitfields'
ovasCDriverTMSiRefa32B.cpp
E:\ncl_EEG\OpenVibe\openvibe-0.13.1-svn3210-src\openvibe-applications\acquisitio
n-server\trunc\src\tmsi-refa32b\ovasCDriverTMSiRefa32B.cpp : warning C4819: The
file contains a character that cannot be represented in the current code page (9
36). Save the file in Unicode format to prevent data loss
e:\ncl_eeg\openvibe\openvibe-0.13.1-svn3210-src\openvibe-applications\acquisitio
n-server\trunc\src\tmsi-refa32b\../ovasIDriver.h : warning C4819: The file conta
ins a character that cannot be represented in the current code page (936). Save
ovCIdentifier.h : warning C4819: The file contains a character that cannot be re
presented in the current code page (936). Save the file in Unicode format to pre
vent data loss
ovCString.h : warning C4819: The file contains a character that cannot be repres
ented in the current code page (936). Save the file in Unicode format to prevent
 data loss
 data loss
ovIMatrix.h : warning C4819: The file contains a character that cannot be repres
 data loss
ovIObject.h : warning C4819: The file contains a character that cannot be repres
 data loss
vent data loss
ovCMatrix.h : warning C4819: The file contains a character that cannot be repres
 data loss
 data loss
ovIStimulationSet.h : warning C4819: The file contains a character that cannot b
e represented in the current code page (936). Save the file in Unicode format to
 prevent data loss
 data loss
ovCStimulationSet.h : warning C4819: The file contains a character that cannot b
 prevent data loss
 prevent data loss
ovIMemoryBuffer.h : warning C4819: The file contains a character that cannot be
represented in the current code page (936). Save the file in Unicode format to p
revent data loss
 data loss
ovCMemoryBuffer.h : warning C4819: The file contains a character that cannot be
revent data loss
revent data loss
 data loss
 data loss
ovIKernelLoader.h : warning C4819: The file contains a character that cannot be
revent data loss
 data loss
revent data loss
kernel/ovIKernelContext.h : warning C4819: The file contains a character that ca
kernel\../ovIObject.h : warning C4819: The file contains a character that cannot
kernel/ovITypeManager.h : warning C4819: The file contains a character that cann
ot be represented in the current code page (936). Save the file in Unicode forma
kernel\log\ovILogListener.h : warning C4819: The file contains a character that
cannot be represented in the current code page (936). Save the file in Unicode f
kernel/log/ovILogListener.h : warning C4819: The file contains a character that
kernel/player/ovIPlayer.h : warning C4819: The file contains a character that ca
kernel/plugins/ovIPluginManager.h : warning C4819: The file contains a character
 that cannot be represented in the current code page (936). Save the file in Uni
kernel/plugins/ovIPluginModule.h : warning C4819: The file contains a character
that cannot be represented in the current code page (936). Save the file in Unic
kernel/scenario/ovIBox.h : warning C4819: The file contains a character that can
not be represented in the current code page (936). Save the file in Unicode form
kernel/scenario/ovIBoxIO.h : warning C4819: The file contains a character that c
kernel/scenario/ovIBoxProto.h : warning C4819: The file contains a character tha
kernel/scenario/ovIComment.h : warning C4819: The file contains a character that
kernel/scenario/ovILink.h : warning C4819: The file contains a character that ca
kernel/scenario/ovIProcessingUnit.h : warning C4819: The file contains a charact
er that cannot be represented in the current code page (936). Save the file in U
kernel/scenario/ovIScenario.h : warning C4819: The file contains a character tha
plugins/ovIPluginObject.h : warning C4819: The file contains a character that ca
plugins\../ovIObject.h : warning C4819: The file contains a character that canno
plugins/ovIPluginObjectDesc.h : warning C4819: The file contains a character tha
n-server\trunc\src\ovasIHeader.h : warning C4819: The file contains a character
n-server\trunc\src\tmsi-refa32b\ovasCDriverTMSiRefa32B.cpp(382) : error C2001: n
ewline in constant
n-server\trunc\src\tmsi-refa32b\ovasCDriverTMSiRefa32B.cpp(494) : warning C4244:
 '=' : conversion from 'double' to 'OpenViBE::float32', possible loss of data
n-server\trunc\src\tmsi-refa32b\ovasCDriverTMSiRefa32B.cpp(498) : warning C4244:
n-server\trunc\src\tmsi-refa32b\ovasCDriverTMSiRefa32B.cpp(520) : warning C4244:
 'initializing' : conversion from 'const OpenViBE::uint64' to 'OpenViBE::uint32'
NMAKE : fatal error U1077: 'D:\PROGRA~1\MICROS~1.0\VC\bin\cl.exe' : return code
'0x2'
Stop.
NMAKE : fatal error U1077: '"D:\Program Files\Microsoft Visual Studio 10.0\VC\BI
N\nmake.exe"' : return code '0x2'
Stop.
Stop.
PostPosted: Fri May 18, 2012 4:10 pm
This problem has been fixed.
Code:
'0x2'
Stop.
Stop.
Stop.
As we can see, the compiling is stopped by the file "ovasCDriverTMSiRefa32B.cpp". I found another post have similar problem only differ in the OS. I took the same file uploaded by jlegeny see http://openvibe.inria.fr/forum/viewtopic.php?f=4&t=576 and replace the same file in my openvibe project. Problem solved, except there are still a lot of warnings. But the Openvibe can function properly. I acutally tried on server PC, in Win7 + Vs2010 enviorment, 3 computers are failed in compile the source code if ovasCDriverTMSiRefa32B.cpp has not been replaced. Is this a bug in the current release? It would be very useful if someone can tell me why this error occurred in the first place.
And i have an other question, i also download a installer file for testing my gtec Usbamp device. In the installation version, i can find the gtec support in the server list, whereas this device's driver can not be found in my complied version. Can someone explaine me how to get gtec device supported in the source file? Do i need to program something extra?
Thank you very much
Wang Yubo
But it will be very useful if someone can tell me why this error happened.
PostPosted: Fri May 18, 2012 4:36 pm
And i also dig a little deeper. I compared the new file which provided by jlegeny and the old file which responsible for my failed compiling. Here is the difference between two files.
In the left panel is the new file, in the right panel is the old file. The difference is highlight in a red box. I do not what happened there, but definitely some coding error. When i compile the source code, there are a lot of warnings related to this coding.
Can someone explain what is wrong with this code. I also tried with the SVN version, the error remains.
PostPosted: Mon May 21, 2012 12:12 pm
Hello Alex,
thanks for this bug report. I have modified the files and the encoding should not be a problem as of now.
Thank you
_________________
cron
POWERED_BY
Translated by MaĆ«l Soucaze © 2009 phpBB.fr
