It is currently Fri Feb 28, 2020 9:07 am
PostPosted: Mon Sep 07, 2009 1:21 pm
ringo-ring asked in this thread an off-topic question I'll answer here :
ringo-ring wrote:
How to rebuild only OpenViBEAcquisitionServer? Running whole win32-build.cmd takes a lot of time...
The build win32-build.cmd script looks for modified files and compiles / links only those files / projects. If you only want to compile the acquisition server, just limit your modifications to this project. If you actually limit your modifications and the win32-build.cmd script keeps compiling the whole platform, either you ran win32-clean.cmd script (so you of course need to re-compile everything), or you have misconfigured time/date on your computer (the "modified" status of a file / project is deduced from the date of the source file and its corresponding object file).
PostPosted: Mon Sep 07, 2009 3:51 pm
Yes, I noticed it does not rebuild everything, but it does check everything and it takes a lot of time on my laptop. Maybe there is a way to shut off those checks too?
PostPosted: Wed Sep 09, 2009 9:54 am
No, because if it does not check, it can't build modified things anymore. If you run Windows and have an antivirus running, you can disable on-access scan. That would speed up things. On my Linux box, it takes less than a second.
I'm sorry to tell you that after that, if you need faster access, you'll have to get a faster computer / faster hard drive ;)
PostPosted: Wed Sep 09, 2009 9:58 am
Ok, one second was not true :)
Code:
[11:55:44|yrenard@cervelet] [svn-repository:~/openvibe] /scripts/ # time ./linux-build
blah blah
real    0m5.677s
user    0m3.192s
sys     0m1.620s
so it is less than 6 seconds.
