gtk/gtk.h cannot be opened, no such file or directory
sam
Post by sam »
HI,
Again this message but with ubuntu 11.10 this time..
Any suggestion please ?
jlegeny
Re: gtk/gtk.h cannot be opened, no such file or directory
Post by jlegeny »
Hello sam,
Most dependency problems on Ubuntu can be solved by following these steps:
* completely remove the scripts/software folder
* assure yourself that dpkg is NOT running (this means that the updater is not running, you are not installing any software in background etc)
* run the linux-install_dependencies script
* recompile OpenViBE
If the problem is not solved after this, please tell us more about your installation (which openvibe version are you using, provide logs from the folder scripts/software/logs, give us more information about the error)
sam
Post by sam »
I confess I didn't watch all the forum here, but here is a draft list of missing packages from a very fresh ubuntu 11 desktop install (accept all dependencies that shows up when selecting these packages : (Some are tricky to find for newbies even with synaptic depending on error message)
g++
gfortran
subversion
automake
autoconf
libitpp dev
doxygen
libtool
libxaw7 dev
cmake
libfreetype
libxxf86vm dev
libpcre
liblua5.1 * dev
libtolua5.1 * dev
expat
libexpat dev
Hope this helps !
jlegeny
Post by jlegeny »
Hello sam,
All of these packages are installed by the dependency install script in case that it executes correctly.
The exact list of packages passed to apt-get install is this one:
subversion doxygen make automake autoconf cmake unzip gcc g++ libgtk2.0-dev libglade2-dev gfortran libgsl0-dev libexpat1-dev libreadline-dev libzzip-dev libtool libxaw7-dev libpcre3-dev libfreeimage-dev libglu1-mesa-dev libalut-dev libvorbis-dev
sam
Post by sam »
hI,
if I'm just supposed to run ./linux-install_dependancies, this script isn't installing the packages I mentioned.
Numerous try on different computer right after Ubutuntu install.
Sam
jlegeny
Post by jlegeny »
hello sam,
did you manage to solve the problem on your side? If not, could you please provide the log found in scripts/software/log/native-packages.log ?
sam
Post by sam »
I clearly managed to get OV correctly compiled. My post was more to draw your attention to the linux install dependancies that doesn't work correctly with a fresh ubuntu setup.
Sam
