But I'm now having problems on another Win7 machine building either source
WARNING: Microsoft Visual Studio Common tools initialisation script not found.
I'm following the Build Instructions, but am receiving the above error and so it won't compile. I've installed Microsoft Visual Studio Express 2010 (specifically, the Visual C++ Express edition). I then ran win32-install_dependencies and that all checked out. But when I run win32-build this is the output I receive:
Code: Select all
build type is set to: Release.
Init-env Script to be called: win32-init_env_command.cmd.
## WARNING : Microsoft Visual Studio Common tools initialisation script not found ##
_______________________________________________________________________________
Configuring and building openvibe\trunc ...
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
-- Check for CL compiler version
-- Check for CL compiler version - failed
-- Check if this is a free VC compiler
-- Check if this is a free VC compiler - yes
-- Using FREE VC TOOLS, NO DEBUG available
-- Check for working C compiler: cl
CMake Error: your C compiler: "cl" was not found. Please set CMAKE_C_COMPILER
to a valid compiler path or name.
CMake Error: Internal CMake error, TryCompile configure of cmake failed
-- Check for working C compiler: cl -- broken
CMake Error at C:/OpenVibe/openvibe-0.12.0-svn3107-src/dependencies/cmake/cmake-
2.8.2-win32-x86/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake:52 (MESSAGE):
The C compiler "cl" is not able to compile a simple test program.
It fails with the following output:
CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
CMakeLists.txt:1 (PROJECT)
CMake Error: your C compiler: "cl" was not found. Please set CMAKE_C_COMPILER to a valid compiler path or name.
CMake Error: your CXX compiler: "cl" was not found. Please set CMAKE_CXX_COMPILER to a valid compiler path or name.
-- Configuring incomplete, errors occurred!
An error occured during building process
Press any key to continue . . .
Some more details: I am building under Windows 7, and I am using the openvibe-0.12.0-svn3107-src source.
