[Arch Linux| Installation
efx
Post by efx »
I adapted the linux-install_dependencies for Arch linux distribution. It uses pacman (the arch linux package manager) to install the following dependencies :
subversion doxygen make automake autoconf cmake unzip gcc g++ libgtk2.0-dev libglade2-dev libitpp-dev libgsl0-dev libexpat1-dev libois-dev libreadline5-dev libzzip-dev libtool libxaw7-dev libpcre3-dev libfreeimage-dev libglu1-mesa-dev libalut-dev libvorbis-dev
Whereas
Pthreadstubs / clearlooks / boost / itpp_external / ois / cg / ogre.
are compiled.
Below is the relevant code. It should be put just after the line
 echo "Checking native dependencies..."
in the ./scripts/linux-install_dependencies file.
	if [[ "`grep Arch /etc/issue 2> /dev/null`" != "" ]]; then
		ov_native_package_installed=true
		ov_native_package_log_file="$ov_target_folder_log/native-packages.log"
		ov_arch_packages="cmake pkgconfig expat xml2 gettext xproto zlib libpng freetype2 fontconfig libtool  xtrans libxslt libxau xcb-proto libxcb kbproto inputproto libxdmcp libx11 libxext xextproto renderproto libxdmcp libxrender libice libsm libxt libxmu libxpm libxaw xf86vidmodeproto xextproto randrproto glib pixman cairo pango atk gtk libglade glade  freeimage zziplib libxrandr libxxf86vm"
		for package in $ov_arch_packages; do
			ov_pacman_output=`pacman -Qs $package 2>&1`
			ov_pacman_retcode=$?
			if [[ $ov_pacman_retcode != 0 ]]; then
				ov_native_package_installed=false
			fi;
			if [[ "$ov_pacman_output" == "" ]]; then
			fi;
		done;
		if [[ $ov_native_package_installed == false ]]; then
			echo "  You are currently running Arch"
			echo ""
			echo "  It is possible to install native packages in order to avoid some potential"
			echo "  errors / save time. Such installation requires root access. If you want"
			echo "  to continue with native packages, answer 'yes' (recommanded)"
			echo ""
			if [[ -e "$ov_target_folder_hit/native-packages.hit" || $ov_native_package_forced == true ]]; then
				echo "  Do you want to install native packages (y) ? automatically selected yes"
				ov_answer=yes
			else
				echo -n "  Do you want to install native packages (y) ?"
				read ov_answer
			fi;
			if [[ $ov_answer == "yes" || $ov_answer == "y" || $ov_answer == "" ]]; then
				echo "  Installing native packages on background..."
				# sudo -k # revokes root privilege
				# sudo apt-get --assume-yes install $ov_ubuntu_packages > $ov_native_package_log_file 2>&1
				su -c "pacman -S $ov_ubuntu_packages > $ov_native_package_log_file 2>&1"
				# su -C "yaourt -S itpp"
				echo "  Installing native packages on background... done."
				ov_should_hit_native=true
			else
				echo "  All right, we will compile everything..."
			fi;
		else
			if [[ -e "$ov_target_folder_hit/native-packages.hit" ]]; then
				echo "  You are currently running Arch and all required native packages were"
				echo "  installed previously, continuing..."
			else
				echo "  You are currently running Arch and all necessary native dependencies are"
				echo "  already installed."
				echo ""
				echo "  It is possible to install use those native packages in order to avoid some potential"
				echo ""
				if [[ $ov_native_package_forced == true ]]; then
					echo "  Do you want to use native packages (y) ? automatically selected yes"
				else
					echo -n "  Do you want to use native packages (y) ?"
					read ov_answer
					fi;
				fi;
			fi;
		fi;
		if [[ $ov_should_hit_native == true ]]; then
			ov_hit_package "native-packages"
			ov_hit_package "pkgconfig"
			ov_hit_package "cmake"
			ov_hit_package "expat"
			ov_hit_package "libxml"
			ov_hit_package "gettext"
#			ov_hit_package "pthreadstubs"
			ov_hit_package "zlib"
			ov_hit_package "libpng"
			ov_hit_package "freetype"
			ov_hit_package "fontconfig"
			ov_hit_package "libtool"
			ov_hit_package "libxproto"
			ov_hit_package "libxextproto"
			ov_hit_package "libxtrans"
			ov_hit_package "libxslt"
			ov_hit_package "libxau"
			ov_hit_package "libxcbproto"
			ov_hit_package "libxcb"
			ov_hit_package "libkbproto"
			ov_hit_package "libinputproto"
			ov_hit_package "libxdmcp"
			ov_hit_package "libx11"
			ov_hit_package "libxext"
			ov_hit_package "renderproto"
			ov_hit_package "libxrender"
			ov_hit_package "libice"
			ov_hit_package "libsm"
			ov_hit_package "libxt"
			ov_hit_package "libxmu"
			ov_hit_package "libxpm"
			ov_hit_package "libxaw"
			ov_hit_package "libxf86vidmodeproto"
			ov_hit_package "libXxf86vm"
			ov_hit_package "librandrproto"
			ov_hit_package "libXrandr"
			ov_hit_package "mesa"
			ov_hit_package "glib"
			ov_hit_package "pixman"
			ov_hit_package "cairo"
			ov_hit_package "pango"
			ov_hit_package "atk"
			ov_hit_package "gtk"
#			ov_hit_package "clearlooks"
			ov_hit_package "libglade"
			ov_hit_package "glade"
#			ov_hit_package "boost"
#			ov_hit_package "itpp_external"
			ov_hit_package "itpp"
			ov_hit_package "gsl"
			ov_hit_package "freeimage"
#			ov_hit_package "ois"
			ov_hit_package "zziplib"
#			ov_hit_package "cg"
#			ov_hit_package "ogre"
#			mkdir "$ov_target_folder_lib/OGRE" 2> /dev/null
#			rm "$ov_target_folder_lib/OGRE/Plugins.cfg" 2> /dev/null
#			echo "# Define plugin folder" >> "$ov_target_folder_lib/OGRE/Plugins.cfg"
#			echo "PluginFolder=/usr/lib/OGRE" >> "$ov_target_folder_lib/OGRE/Plugins.cfg"
#			echo "" >> "$ov_target_folder_lib/OGRE/Plugins.cfg"
#			echo "# Define plugins" >> "$ov_target_folder_lib/OGRE/Plugins.cfg"
#			echo "Plugin=RenderSystem_GL" >> "$ov_target_folder_lib/OGRE/Plugins.cfg"
#			echo "Plugin=Plugin_ParticleFX" >> "$ov_target_folder_lib/OGRE/Plugins.cfg"
#			echo "Plugin=Plugin_BSPSceneManager" >> "$ov_target_folder_lib/OGRE/Plugins.cfg"
#			echo "Plugin=Plugin_OctreeSceneManager" >> "$ov_target_folder_lib/OGRE/Plugins.cfg"
#			echo "#Plugin=Plugin_CgProgramManager" >> "$ov_target_folder_lib/OGRE/Plugins.cfg"
		else
			ov_hit_package "no-native-packages"
		fi;
	fi;
[EDIT]
I forgot something for the compilation to work properly on Arch Linux.
If you have a problem during the building of clearlooks you can just add this piece of code before the line 184 (starting with ./configure --prefix=...)
			if [ "$ov_current_package" == "clearlooks" ]; then
				cd $ov_target_folder_arch/$ov_current_package_archive_name
				echo "autoreconf needed"
				autoreconf --force --install --symlink
			fi;
in the linux_install_dependencies script
lbonnet
Re: [Arch Linux| Installation
Post by lbonnet »
Many thanks efx !
If someone out there is willing to give it a try, please let us know.
Chears,
I just wrote a new blog post about how to compile OpenViBE on a new Linux distro.
I hope this helps future contributors !
