Users wishing to debug the software may want to switch to Debug mode. This can be done by changing the build type in the win32-build.cmd script file (linux-build.cmd for Linux developers):
cmake -DCMAKE_BUILD_TYPE=Debug
Finally, Windows developers wishing to use 3D features should edit their configuration file (by default, openvibe-kernel-omk\trunc\share\openvibe.conf) and enable the right token, depending on the build type :
#comment out this token when build type is Debug
#Kernel_3DVisualisationOgrePluginsWindows = $Environment{OGRE_HOME}/bin/release/Plugins.cfg
Kernel_3DVisualisationOgrePluginsWindows = $Environment{OGRE_HOME}/bin/debug/Plugins.cfg
