~/Downloads/openvibe/local-tmp/openvibe-toolkit/trunc ~/Downloads/openvibe/scripts
Configuring and building openvibe-toolkit/trunc ...
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Found OpenViBE...
-- [ OK ] lib /usr/lib/libOpenViBE-dynamic.so
-- Found OpenViBE module EBML...
-- [ OK ] lib /home/mindbound/Downloads/openvibe/openvibe-modules/ebml/trunc/lib/libOpenViBE-module-EBML-dynamic.so
-- Found OpenViBE module System...
-- [ OK ] lib /usr/lib/libOpenViBE-module-System-dynamic.so
-- Configuring done
-- Generating done
-- Build files have been written to: /home/mindbound/Downloads/openvibe/local-tmp/openvibe-toolkit/trunc
CMake has been called successfully !
Scanning dependencies of target OpenViBE-toolkit-dynamic
[ 3%] [ 6%] [ 9%] Building CXX object CMakeFiles/OpenViBE-toolkit-dynamic.dir/src/ovtk_main.o
Building CXX object CMakeFiles/OpenViBE-toolkit-dynamic.dir/src/openvibe-toolkit/training/ovtkCSignalTrialSet.o
Building CXX object CMakeFiles/OpenViBE-toolkit-dynamic.dir/src/openvibe-toolkit/training/ovtkISignalTrial.o
In file included from /home/mindbound/Downloads/openvibe/openvibe-toolkit/trunc/src/openvibe-toolkit/ovtk_all.h:74:0,
from /home/mindbound/Downloads/openvibe/openvibe-toolkit/trunc/src/ovtk_main.cpp:1:
/home/mindbound/Downloads/openvibe/openvibe-toolkit/trunc/src/openvibe-toolkit/box-algorithms/ovtkTTrainingBoxAlgorithm.h: In member function 'virtual void OpenViBEToolkit::TTrainingBoxAlgorithm<CBoxAlgorithmParentClass>::setStimulation(OpenViBE::uint32, OpenViBE::uint64, OpenViBE::uint64)':
/home/mindbound/Downloads/openvibe/openvibe-toolkit/trunc/src/openvibe-toolkit/box-algorithms/ovtkTTrainingBoxAlgorithm.h:213:7: error: 'time64' is not a member of 'OpenViBE'
/home/mindbound/Downloads/openvibe/openvibe-toolkit/trunc/src/openvibe-toolkit/box-algorithms/ovtkTTrainingBoxAlgorithm.h:222:7: error: 'time64' is not a member of 'OpenViBE'
/home/mindbound/Downloads/openvibe/openvibe-toolkit/trunc/src/openvibe-toolkit/box-algorithms/ovtkTTrainingBoxAlgorithm.h:241:7: error: 'time64' is not a member of 'OpenViBE'
/home/mindbound/Downloads/openvibe/openvibe-toolkit/trunc/src/openvibe-toolkit/box-algorithms/ovtkTTrainingBoxAlgorithm.h:252:7: error: 'time64' is not a member of 'OpenViBE'
/home/mindbound/Downloads/openvibe/openvibe-toolkit/trunc/src/openvibe-toolkit/box-algorithms/ovtkTTrainingBoxAlgorithm.h:254:7: error: 'time64' is not a member of 'OpenViBE'
make[2]: *** [CMakeFiles/OpenViBE-toolkit-dynamic.dir/src/ovtk_main.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [CMakeFiles/OpenViBE-toolkit-dynamic.dir/all] Error 2
make: *** [all] Error 2
