It is currently Sat Feb 24, 2018 2:30 am
PostPosted: Thu Sep 12, 2013 1:20 pm
hi all
i try to compile the latest source code, but get the fatal error U1077, which according the the forum can be solved by disabling the matlab box in the win32-init-env-command.cmd file.
if i open this file, there is only
@echo off
REM ########################################################################################################################
if exist "win32-dependencies.cmd" (
call "win32-dependencies.cmd"
) else (
echo ERROR: win32-dependencies.cmd not found. Has the dependency installer been run?
goto terminate
SET VSTOOLS=
SET VSCMake=
if exist "%VS100COMNTOOLS%vsvars32.bat" (
echo Found VS100 tools...
CALL "%VS100COMNTOOLS%vsvars32.bat"
SET VSCMake=Visual Studio 10
) else if exist "%VS90COMNTOOLS%vsvars32.bat" (
echo Found VS90 tools...
CALL "%VS90COMNTOOLS%vsvars32.bat"
SET VSCMake=Visual Studio 9 2008
) else (
echo ######################################################################################
echo ## ##
echo ## ERROR : Microsoft Visual Studio Common tools initialisation script not found ##
echo ## ##
goto terminate
:terminate
so apparently , i should remove the matlab box compilation somewhere else ... does someone know where i can find it?
thanks
maarten
PostPosted: Thu Sep 12, 2013 1:32 pm
Hi mdv,
with the more recent OpenViBE versions, e.g. 0.16.0+, there's a few ways.
1) Easy and dirty way to remove a plugin is just to delete the directory subtree and make a clean build. In this case, delete the folder
plugins/processing/matlab/
2) A more advanced way is to add the following to the root level CMakeLists.txt
SET(SKIP_PLUGINS_PROCESSING_MATLAB "1")
PostPosted: Thu Sep 12, 2013 2:09 pm
solution 1 was successful
thanks!
maarten
