It is currently Tue Mar 20, 2018 11:44 am
PostPosted: Fri May 31, 2013 4:30 pm
I would like to know if it is possible to send messages to the INF console at the bottom of the OpenVibe screen designer.
Lets use a simple scenario connecting the 2 modules: "Clock stimulator" and "Run Command"
"Clock stimulator" defined as:
Intervalstimulation interval (in sec): 10.00000
Stimluation: OVTK_StimulationId_Label_01
"Run Command" defined as:
Stimulation 1: OVTK_StimulationId_Label_01
Command 1: START notepad
So, each 10 seconds it opens the application notepad.
What I want to do is also to send a message each 10 seconds to the console at the botton of the screen. For example: "Opening notepad..."
PostPosted: Mon Jun 10, 2013 11:10 am
Hello Pedro,
an easy way to display arbitrary messages would be to use the Lua stimulator box.
Add an input to it via right click menu and use it with a simple script such as this:
function initialize(box)
function uninitialize(box)
function process(box)
   while true do
      if (box:get_stimulation_count(1)) then
         box:log("Info", "test")
         box:remove_stimulation(1, 1)
This program will display a message "test" every time it receives a stimulation. For more info look at the lua box documentation here: ... lator.html
