missing driver gmobilab
arakotom
Post by arakotom »
Hi all,
I have successfully compiled the latest linux version of the code on my ubuntu 12.10. My problem is that
I do not see the driver of my acquisition device gtec gmobilab+ in the acquisition server although all
the driver sources are in the appropriate folder (.../openvibe-0.14.3-svn3350-src/openvibe-applications/acquisition-server/trunc/src).
Is there any switch that I need to turn on in order to compile the appropriate driver?
merci pour le coup de main!
A.
jlegeny
Re: missing driver gmobilab
Post by jlegeny »
Hello arakotom,
in order to compile the g.Mobilab driver you will need to have the g.Tec C API installed on the computer as well. In the case the API is installed, could you provide the log from the compilation of the acquisition server?
arakotom
Post by arakotom »
thanks for the answers.
I have installed the gmobilab drivers from gtec (I have the following files /usr/lib/libgMOBIlabplus.so).
then reinstalled all the openvibe source, build the dependencies.
now linux-built breaks with the following errors:
/home/alain/programme/openvibe-0.14.3-svn3350-src/scripts/software/include/boost/exception/detail/exception_ptr.hpp:182:13: required from ‘void boost::unknown_exception::add_original_type(const E&) [with E = std::exception]’
/home/alain/programme/openvibe-0.14.3-svn3350-src/scripts/software/include/boost/exception/detail/exception_ptr.hpp:161:32: required from here
/home/alain/programme/openvibe-0.14.3-svn3350-src/scripts/software/include/boost/checked_delete.hpp:34:5: attention : deleting object of polymorphic class type ‘boost::error_info<boost::tag_original_exception_type, const std::type_info*>’ which has non-virtual destructor might cause undefined behaviour [-Wdelete-non-virtual-dtor]
Linking CXX executable OpenViBE-acquisition-server-dynamic
/usr/bin/ld: escamotage incompatible /usr/lib/gcc/x86_64-linux-gnu/4.7/../../../../lib/libgMOBIlabplus.so lors de la recherche de -lgMOBIlabplus
/usr/bin/ld: escamotage incompatible /usr/lib/../lib/libgMOBIlabplus.so lors de la recherche de -lgMOBIlabplus
/usr/bin/ld: escamotage incompatible /usr/lib/gcc/x86_64-linux-gnu/4.7/../../../libgMOBIlabplus.so lors de la recherche de -lgMOBIlabplus
/usr/bin/ld: escamotage incompatible /usr/lib/libgMOBIlabplus.so lors de la recherche de -lgMOBIlabplus
/usr/bin/ld: ne peut trouver -lgMOBIlabplus
collect2: erreur: ld a retourné 1 code d'état d'exécution
make[2]: *** [OpenViBE-acquisition-server-dynamic] Erreur 1
make[1]: *** [CMakeFiles/OpenViBE-acquisition-server-dynamic.dir/all] Erreur 2
make: *** [all] Erreur 2
thanks for the help.
A.
jlegeny
Post by jlegeny »
is it possible that you have installed a 32bit driver on your 64bit Linux? Other issue could be an incompatibility of the driver versions.
