It is currently Tue Nov 12, 2019 11:21 pm
Post new topic Reply to topic  [ 10 posts ]
PostPosted: Tue Feb 22, 2011 1:17 pm
Dear All,
I can't figure out what I'm doing wrong when using the scripts.
I want to build OpenViBE 0.9.0 on Windows XP with msvc9 (VC 2008).
Following the INSTALL recommendations:
- I launched win32-install_dependencies.exe.
- I Saved win32-init_env_command.cmd-skeleton as win32-init_env_command.cmd
- I opened win32-init_env_command.cmd and then the wierd stuff started ...
First I had to change the following lines:
Code:
if exist "!VS90COMNTOOLS!\vsvars32.bat" (
   SET VSTOOLS=!VS90COMNTOOLS!\vsvars32.bat
   SET VSCMake=Visual Studio 9 2008
by
Code:
if exist "%VS90COMNTOOLS%vsvars32.bat" (
   SET VSTOOLS=%VS90COMNTOOLS%vsvars32.bat
But that only solved my issue with Visual Studio tools detection ...
I'm not that familiar with the type of scripts you are using but I see a lots of those "!" char and as it was the source of the initial error message, I woudl like to be sure that the following part of the script is right:
Code:
for /D %%s in (%OpenViBE_modules%/*) do (
   set OpenViBE_project_name=%%~ns
   REM echo OpenViBE_project_name %OpenViBE_project_name%
   set OpenViBE_project_name=!OpenViBE_project_name:-=_!
   echo if "%%OpenViBE_module_!OpenViBE_project_name!_branch%%" == "" SET OpenViBE_module_!OpenViBE_project_name!_branch=%OpenViBE_default_branch% >> tmp_branch.cmd
   echo set OpenViBE_module_!OpenViBE_project_name!=%OpenViBE_modules%\%%~ns\%OpenViBE_percent%OpenViBE_module_!OpenViBE_project_name!_branch%OpenViBE_percent% >> tmp_branch.cmd
   call tmp_branch.cmd
   del tmp_branch.cmd
As you can see I tried to echo the OpenViBE_project_name variable but I only got: "!OpenViBE_project_name:-=_!".
My console outputs (with the echo commented):
Code:
Setting environment for using Microsoft Visual Studio 2008 x86 tools.
The input line is too long.
The syntax of the command is incorrect.
Then it does not compile.
PostPosted: Tue Feb 22, 2011 2:36 pm
Dear Tangi,
welcome on this forum and thank you for your interest in OpenViBE.
The first thing is that we should update the install instructions since they are outdated. The step where you copy and edit the win32-init_env_command.cmd script is only mandatory for developers having a branch in the SVN repository. People building the software from the trunc actually don't have to do this step anymore.
This said, the fact that you have to replace ! with % in order to detect visual is not expected. Those two different ways of writing environment variables on windows scripts causes really different behavior (see retarded variable expansion or something similar). So they should be left with ! where specified. And we should focus on why your command interpreter is not detecting them correctly.
Can you give more information about your box ? (Version of WinXP, service pack, is it a modified - maybe unofficial ;) - version of Windows, did you install anything that could interfere with the traditional command line interpreter etc...). By the way, did you try to compile the software from a console you opened yourself or did you just double click the .cmd script ? (the second one is correct)
I look forward to your feedbacks.
Meanwhile, just delete your win32-init_env_command.cmd file ; the call to win32-build.cmd script will just create a fresh one for you.
_________________
PostPosted: Tue Feb 22, 2011 3:03 pm
Ok, interesting, until now, I always performed the same steps as Tangi (only changing the '!' with '%' so that it detects the compiler) and I have an official 32-bit XP version, service pack 3 (2600.xpsp_sp3_gdr.101209-1647). Off course, as long as it worked for me, I didn't question the method.
I also sometimes get the final error that Tangi gave ("input too long") because I first opened a prompt and then executed the script too many times with as consequence that the PATH variable got too long and the script failed. Restarting the prompt and thus resetting the PATH worked fine for me, off course double clicking avoids all that.
Dieter Devlaminck
PostPosted: Tue Feb 22, 2011 3:11 pm
Ok ...
Windows XP pro service pack 3 with Windos SDK 6.0 installled.
I tried both: from a visual studio command prompt and by double clicking on it.
I tried that ...
It seems CMake can not find the expat module ... It is installed in the dependencies folder ... but strangely the expat.h as well as many other .h files are in a "lib" repository ...
\dependencies\expat\Source\lib
Code:
Configuring and building openvibe-modules\xml\trunc ...
--   FAILED to find expat...
-- Configuring done
-- Generating done
-- Build files have been written to: D:/Devs/MINDWALKER/OpenVibe/openvibe-0.9.0-
svn2639-src/local-tmp/openvibe-modules/xml/trunc
Copyright (C) Microsoft Corporation.  All rights reserved.
[ 33%] Building CXX object CMakeFiles/OpenViBE-module-XML-dynamic.dir/src/xml/IR
eader.obj
IReader.cpp
D:\Devs\MINDWALKER\OpenVibe\openvibe-0.9.0-svn2639-src\openvibe-modules\xml\trun
c\src\xml\IReader.cpp(3) : fatal error C1083: Cannot open include file: 'expat.h
': No such file or directory
NMAKE : fatal error U1077: 'C:\PROGRA~1\MICROS~2.0\VC\bin\cl.exe' : return code
'0x2'
Stop.
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio 10.0\VC\BI
N\nmake.exe"' : return code '0x2'
Stop.
Stop.
I'm also interested on info regarding how to tell the script to take visual studio 2008 instead of 2010 ...
PostPosted: Tue Feb 22, 2011 4:28 pm
Ok, we should find a way to detect the user used a console and tell him it will end up with an error.
:) We did not re-package the expat archive, this is the one from their website. Anyway, our script should consider this "non standard" location and deal with it. I think that in order to step back to a clean environment, you should consider running win32-clean.cmd before trying to build OpenViBE again.
Interesting remark ! So was this the reason why you had to use % instead of ! ?
The environment initialization uses the latest version of visual installed on your system. If you don't want to use visual 2010 and prefer using visual 2008 (which will need SP1 !), just remove the following lines in the win32-init_env_command.cmd script :
Code:
if exist "!VS100COMNTOOLS!\vsvars32.bat" (
   SET VSTOOLS=!VS100COMNTOOLS!\vsvars32.bat
   SET VSCMake=Visual Studio 10 2010
This will cancel detection of Visual 2010 :)
_________________
PostPosted: Wed Feb 23, 2011 9:21 am
I already tried to clean but it does not change anything ...
I had seen this in the script and modified it but you told me
So if the init_env_command script is now generated by the build script, how can I modify it ...???
Thanks for your help,
Tangi
PostPosted: Wed Feb 23, 2011 10:31 am
Because of your question, I tried to update my installation to the newest version (about time I did this) and I faced again the same problem as you. I uninstalled all my dependencies and reinstalled them again and it worked. I'm not yet sure why it worked, maybe because the file win32-dependencies.cmd, that is generated during executing of the win32-install_dependencies.exe, was changed? win32-dependencies.cmd sets some important variables so that the cmake file "FindThirdPartyExpat.cmake" can do their work.
So maybe the variable in win32-dependencies.cmd "SET OV_DEP_EXPAT=..." is set to the wrong path?
If you did not have a win32-init_env_command.cmd script it was made for you when executing win32-build, if you then remove the lines in win32-init_env_command.cmd for detection of visual studio 2010 it should take the 2008; no?
Dieter Devlaminck
PostPosted: Wed Feb 23, 2011 1:34 pm
Ok, it seems to work after cleaning everything. Thanks a lot Dieter.
PostPosted: Thu Feb 24, 2011 10:16 am
That's great,
thank you Dieter for your help in solving this. Is there any update we should consider in the building scripts so this never happens again ?
Tanguy, you can now have fun with OpenViBE ;)
_________________
PostPosted: Thu Feb 24, 2011 11:40 am
The problem is that I'm still not exactly sure what went wrong. I also updated my version of OpenVibe on my laptop yesterday and there that problem did not occur, everything went very smooth in contrast to the update of our recording desktop where I only had the above problem of not finding expat. If I find out what exactly went wrong, I'll let you know.
Dieter Devlaminck
cron
