Error building CEGUI with linux-install_dependancies
fabien.lotte
Post by fabien.lotte »
Hi guys,
I am trying to install OpenViBE on my machine (x86_64, Ubuntu 10.10, gcc 4.4.5), and I got an error while building CEGUI with the linux-install-dependancies script.
Here is the error I got (from file cegui.log):
make[4]: entrant dans le répertoire « /home/fabien/code/trunk/scripts/software/tmp/CEGUI-0.7.1/cegui/src/ImageCodecModules/DevILImageCodec »
/bin/bash ../../../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../../../cegui/include -I../../../../cegui/include -I../../../../cegui/include/ImageCodecModules/DevILImageCodec -DUSE_DEVIL_LIBRARY  -I/home/fabien/code/trunk/scripts/software/include  -g -O2 -MT libCEGUIDevILImageCodec_la-CEGUIDevILImageCodec.lo -MD -MP -MF .deps/libCEGUIDevILImageCodec_la-CEGUIDevILImageCodec.Tpo -c -o libCEGUIDevILImageCodec_la-CEGUIDevILImageCodec.lo `test -f 'CEGUIDevILImageCodec.cpp' || echo './'`CEGUIDevILImageCodec.cpp
/bin/bash ../../../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../../../cegui/include -I../../../../cegui/include -I../../../../cegui/include/ImageCodecModules/DevILImageCodec -DUSE_DEVIL_LIBRARY  -I/home/fabien/code/trunk/scripts/software/include  -g -O2 -MT libCEGUIDevILImageCodec_la-CEGUIDevILImageCodecModule.lo -MD -MP -MF .deps/libCEGUIDevILImageCodec_la-CEGUIDevILImageCodecModule.Tpo -c -o libCEGUIDevILImageCodec_la-CEGUIDevILImageCodecModule.lo `test -f 'CEGUIDevILImageCodecModule.cpp' || echo './'`CEGUIDevILImageCodecModule.cpp
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../../../cegui/include -I../../../../cegui/include -I../../../../cegui/include/ImageCodecModules/DevILImageCodec -DUSE_DEVIL_LIBRARY -I/home/fabien/code/trunk/scripts/software/include -g -O2 -MT libCEGUIDevILImageCodec_la-CEGUIDevILImageCodec.lo -MD -MP -MF .deps/libCEGUIDevILImageCodec_la-CEGUIDevILImageCodec.Tpo -c CEGUIDevILImageCodec.cpp  -fPIC -DPIC -o .libs/libCEGUIDevILImageCodec_la-CEGUIDevILImageCodec.o
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../../../cegui/include -I../../../../cegui/include -I../../../../cegui/include/ImageCodecModules/DevILImageCodec -DUSE_DEVIL_LIBRARY -I/home/fabien/code/trunk/scripts/software/include -g -O2 -MT libCEGUIDevILImageCodec_la-CEGUIDevILImageCodecModule.lo -MD -MP -MF .deps/libCEGUIDevILImageCodec_la-CEGUIDevILImageCodecModule.Tpo -c CEGUIDevILImageCodecModule.cpp  -fPIC -DPIC -o .libs/libCEGUIDevILImageCodec_la-CEGUIDevILImageCodecModule.o
mv -f .deps/libCEGUIDevILImageCodec_la-CEGUIDevILImageCodecModule.Tpo .deps/libCEGUIDevILImageCodec_la-CEGUIDevILImageCodecModule.Plo
mv -f .deps/libCEGUIDevILImageCodec_la-CEGUIDevILImageCodec.Tpo .deps/libCEGUIDevILImageCodec_la-CEGUIDevILImageCodec.Plo
/bin/bash ../../../../libtool --tag=CXX   --mode=link g++  -g -O2 -release 0.7.1 -L/home/fabien/code/trunk/scripts/software/lib -L/home/fabien/code/trunk/scripts/software/lib64 -o libCEGUIDevILImageCodec.la -rpath /home/fabien/code/trunk/scripts/software/lib libCEGUIDevILImageCodec_la-CEGUIDevILImageCodec.lo libCEGUIDevILImageCodec_la-CEGUIDevILImageCodecModule.lo -lIL -lILU ../../../../cegui/src/libCEGUIBase.la -lglut -lGLU -lGL  -lSM -lICE
libtool: link: warning: `/usr/lib/gcc/x86_64-linux-gnu/4.4.5/../../../../lib/libfreetype.la' seems to be moved
libtool: link: g++ -shared -nostdlib /usr/lib/gcc/x86_64-linux-gnu/4.4.5/../../../../lib/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.4.5/crtbeginS.o  .libs/libCEGUIDevILImageCodec_la-CEGUIDevILImageCodec.o .libs/libCEGUIDevILImageCodec_la-CEGUIDevILImageCodecModule.o   -Wl,-rpath -Wl,/home/fabien/code/trunk/scripts/software/tmp/CEGUI-0.7.1/cegui/src/.libs -Wl,-rpath -Wl,/home/fabien/code/trunk/scripts/software/lib -L/home/fabien/code/trunk/scripts/software/lib -L/home/fabien/code/trunk/scripts/software/lib64 -L/usr/lib /usr/lib/libILU.so /usr/lib/libIL.so /usr/lib/libtiff.so -lpng12 -lmng /usr/lib/liblcms.so /usr/lib/libjpeg.so -lXpm -lXcursor -lpthread -ldl -lXxf86vm ../../../../cegui/src/.libs/libCEGUIBase.so -L/usr/lib/gcc/x86_64-linux-gnu/4.4.5/../../../../lib /usr/lib/libfreetype.so -lz -lpcre -lglut -lGLU -lGL -lSM -lICE -L/usr/lib/gcc/x86_64-linux-gnu/4.4.5 -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.4.5/../../.. -lstdc++ -lm -lc -lgcc_s /usr/lib/gcc/x86_64-linux-gnu/4.4.5/crtendS.o /usr/lib/gcc/x86_64-linux-gnu/4.4.5/../../../../lib/crtn.o    -Wl,-soname -Wl,libCEGUIDevILImageCodec-0.7.1.so -o .libs/libCEGUIDevILImageCodec-0.7.1.so
/usr/bin/ld: cannot find -lmng
collect2: ld returned 1 exit status
make[4]: *** [libCEGUIDevILImageCodec.la] Erreur 1
make[4]: quittant le répertoire « /home/fabien/code/trunk/scripts/software/tmp/CEGUI-0.7.1/cegui/src/ImageCodecModules/DevILImageCodec »
make[3]: *** [all-recursive] Erreur 1
make[3]: quittant le répertoire « /home/fabien/code/trunk/scripts/software/tmp/CEGUI-0.7.1/cegui/src/ImageCodecModules »
make[2]: *** [all-recursive] Erreur 1
make[2]: quittant le répertoire « /home/fabien/code/trunk/scripts/software/tmp/CEGUI-0.7.1/cegui/src »
make[1]: *** [all-recursive] Erreur 1
make[1]: quittant le répertoire « /home/fabien/code/trunk/scripts/software/tmp/CEGUI-0.7.1/cegui »
make: *** [all-recursive] Erreur 1
~/code/trunk/scripts/software/tmp ~/code/trunk/scripts
It seems I am missing the "mng" library, is that right? If it is the case, maybe this library should be added to the dependencies as well?
What do you think?
thank you in advance!
Fabien
Re: Error building CEGUI with linux-install_dependancies
Dear fabien,
actually, this dependency is not installed by the linux-install_dependency but is a direct dependency of GIMP which should be pre-installed on Ubuntu (as far as I know). Could you check if this library is actually missing on your system or maybe it is just not found by CEGUI at build time ?
Thank you,
fabien.lotte
Dear Yann,
Thank you for your help! MNG was indeed already installed as you guessed and LD was just unable to find it, for two reasons:
- I didn't check my LD_LIBRARY_PATH variable, and it was actually empty (I am a noob :-)) so it could'nt find MNG which was naturally in usr/lib
- the library was named "libmng.so.1" but there was no symbolic link named "libmng.so", so again LD couldn't find it. I just added this link to solve the problem.
I had the same problem with libXxf86vm, which was of course solved using the same approach. I now have a fully functional and working OpenViBE! Yes!
Thanks again.
Fabien
Dear Fabien,
did you build all the dependencies from sources ? I mean if you are using any ubuntu derivate, you should better install native packages, definitely !
rnatar
Post by rnatar »
Hello all,
I tried to install openvibe 0.13.1 in my Ubuntu 10.04(LTS) 64 bit but I ended up getting the following error.. I tried the solutions of Fabien but still couldnt figure out the problem....
Trying to install package [cegui]...
Downloading [http://sourceforge.net/projects/crayzed ... 7.1.tar.gz] as [CEGUI-0.7.1.tar.gz]...
Downloading [http://sourceforge.net/projects/crayzed ... 7.1.tar.gz] succeeded... (cached)
Uncompressing [/home/rnatar609/openvibe-0.13.1-svn3210-src/scripts/software/arch/CEGUI-0.7.1.tar.gz]...
Uncompressing [/home/rnatar609/openvibe-0.13.1-svn3210-src/scripts/software/arch/CEGUI-0.7.1.tar.gz] succeeded...
Configuring [cegui]...
Configuring [cegui] succeeded...
Building [cegui]...
Building [cegui] failed !
Log file can be found at [/home/rnatar609/openvibe-0.13.1-svn3210-src/scripts/software/log/cegui.log] and ends with :
make[4]: *** [libCEGUITinyXMLParser_la-CEGUITinyXMLParser.lo] Error 1
make[4]: Leaving directory `/home/rnatar609/openvibe-0.13.1-svn3210-src/scripts/software/tmp/CEGUI-0.7.1/cegui/src/XMLParserModules/TinyXMLParser'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/home/rnatar609/openvibe-0.13.1-svn3210-src/scripts/software/tmp/CEGUI-0.7.1/cegui/src/XMLParserModules'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/rnatar609/openvibe-0.13.1-svn3210-src/scripts/software/tmp/CEGUI-0.7.1/cegui/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/rnatar609/openvibe-0.13.1-svn3210-src/scripts/software/tmp/CEGUI-0.7.1/cegui'
make: *** [all-recursive] Error 1
~/openvibe-0.13.1-svn3210-src/scripts/software/tmp ~/openvibe-0.13.1-svn3210-src/scripts
Could anyone throw more light on the problem.....
Ramesh
jlegeny
Post by jlegeny »
Hello Ramesh,
have you managed to resolve your issue?
If not, could you please post the whole logfile? it is located at /home/rnatar609/openvibe-0.13.1-svn3210-src/scripts/software/log/cegui.log . Since the output from the terminal is only the last part of the file. I have tried compiling OpenViBE dependencies on a fresh 10.04-64bit just now and it worked.
florianf
Post by florianf »
I had the same problem just now when I tried to install the current latest version (3676) on ubuntu 12.04. I managed to solve it by installing lua before running the linux-install-dependencies script. ( apt-get install lua5.1 to be precise.)
