Hello everyone,
Happy new year.
I tried compiling the vrpn client using gcc but I find no way to use the vrpn.lib. I have linked the library. I am sure it is using the correct library as when I change the name, the compiler tells me it cannot find the file. But, it always keeps telling me "undefined reference".
Any help would be appreciated. I am using code::blocks to compile.
Compiling vrpn with gcc
Karthik
Karthik
Re: Compiling vrpn with gcc
Hello karthiks,
what OS are you using? .lib libraries are Windows specific and cannot be used on Linux for example.
In order to help you we will need more details about your setup.
Hey Jozef,jlegeny wrote:Hello karthiks,
I am using Windows 7 32 bit. I had the same issue when I was trying to compile stand-alone VRPN clients using Eclipse too. It only compiles well with MSVC++ 2010 express which leads me to think that the libraries may have been compiled with MSVC.
Karthik
Karthik
