It is currently Fri Feb 28, 2020 9:13 am
Post new topic Reply to topic  [ 6 posts ]
PostPosted: Tue Jan 25, 2011 7:24 pm
Hey,
I tried to use the code in the developer documentation to learn how to build a new algorithm and box. But I get the following error -
Code:
Microsoft (R) Program Maintenance Utility Version 9.00.30729.01
Copyright (C) Microsoft Corporation.  All rights reserved.
[100%] Built target OpenViBE-plugins-classification-dynamic
Install the project...
-- Install configuration: "Release"
-- Up-to-date: E:/Openvibe/openvibe-plugins/classification/trunc/lib/OpenViBE-plugins-classification-dynamic.lib
-- Up-to-date: E:/Openvibe/openvibe-plugins/classification/trunc/bin/OpenViBE-plugins-classification-dynamic.dll
Configuring and building openvibe-plugins\classification-gpl\trunc ...
--   Found OpenViBE...
--     [  OK  ] lib E:/Openvibe/openvibe/trunc/lib/OpenViBE-dynamic.lib
--   Found OpenViBE-toolkit...
--     [  OK  ] lib E:/Openvibe/openvibe-toolkit/trunc/lib/OpenViBE-toolkit-dynamic.lib
--   Found OpenViBE module EBML...
--     [  OK  ] lib E:/Openvibe/openvibe-modules/ebml/trunc/lib/OpenViBE-module-EBML-dynamic.lib
--   Found OpenViBE module XML...
--     [  OK  ] lib E:/Openvibe/openvibe-modules/xml/trunc/lib/OpenViBE-module-XML-dynamic.lib
--   Found OpenViBE module System...
--     [  OK  ] lib E:/Openvibe/openvibe-modules/system/trunc/lib/OpenViBE-module-System-dynamic.lib
--   Found OpenViBE plugins global defines...
--   Found it++...
--     [  OK  ] Third party lib E:/Openvibe/dependencies/itpp/lib/libblas.a.lib
--     [  OK  ] Third party lib E:/Openvibe/dependencies/itpp/lib/libfftw3-3.lib
--     [  OK  ] Third party lib E:/Openvibe/dependencies/itpp/lib/liblapack.a.lib
--     [  OK  ] Third party lib E:/Openvibe/dependencies/itpp/lib/libgcc.a.lib
--     [  OK  ] Third party lib E:/Openvibe/dependencies/itpp/lib/libg2c.a.lib
--     [  OK  ] Third party lib E:/Openvibe/dependencies/itpp/lib/itpp.lib
-- Configuring done
-- Generating done
-- Build files have been written to: E:/Openvibe/local-tmp/openvibe-plugins/classification-gpl/trunc
[100%] Built target OpenViBE-plugins-classification-gpl-dynamic
-- Up-to-date: E:/Openvibe/openvibe-plugins/classification-gpl/trunc/lib/OpenViBE-plugins-classification-gpl-dynamic.lib
-- Up-to-date: E:/Openvibe/openvibe-plugins/classification-gpl/trunc/bin/OpenViBE-plugins-classification-gpl-dynamic.dll
Configuring and building openvibe-plugins\feature-extraction\trunc ...
-- Configuring done
-- Generating done
-- Build files have been written to: E:/Openvibe/local-tmp/openvibe-plugins/feature-extraction/trunc
[100%] Built target OpenViBE-plugins-feature-extraction-dynamic
-- Up-to-date: E:/Openvibe/openvibe-plugins/feature-extraction/trunc/lib/OpenViBE-plugins-feature-extraction-dynamic.lib
-- Up-to-date: E:/Openvibe/openvibe-plugins/feature-extraction/trunc/bin/OpenViBE-plugins-feature-extraction-dynamic.dll
Configuring and building openvibe-plugins\file-io\trunc ...
-- Configuring done
-- Generating done
-- Build files have been written to: E:/Openvibe/local-tmp/openvibe-plugins/file-io/trunc
[100%] Built target OpenViBE-plugins-file-io-dynamic
-- Up-to-date: E:/Openvibe/openvibe-plugins/file-io/trunc/lib/OpenViBE-plugins-file-io-dynamic.lib
-- Up-to-date: E:/Openvibe/openvibe-plugins/file-io/trunc/bin/OpenViBE-plugins-file-io-dynamic.dll
Configuring and building openvibe-plugins\samples\trunc ...
-- Configuring done
-- Generating done
-- Build files have been written to: E:/Openvibe/local-tmp/openvibe-plugins/samples/trunc
[  5%] Building CXX object CMakeFiles/OpenViBE-plugins-samples-dynamic.dir/src/ovpCAlgorithmSignalProcessingAlgorithm.obj
ovpCAlgorithmSignalProcessingAlgorithm.cpp
e:\openvibe\openvibe-plugins\samples\trunc\src\ovpCAlgorithmSignalProcessingAlgorithm.h(8) : warning C4005: 'OVP_ClassId_Algorithm_SignalProcessingAlgorithm' :
macro redefinition
        e:\openvibe\openvibe-plugins\samples\trunc\src\ovp_defines.h(10) : see p
revious definition of 'OVP_ClassId_Algorithm_SignalProcessingAlgorithm'
rithm.h(9) : warning C4005: 'OVP_ClassId_Algorithm_SignalProcessingAlgorithmDesc
' : macro redefinition
        e:\openvibe\openvibe-plugins\samples\trunc\src\ovp_defines.h(11) : see p
revious definition of 'OVP_ClassId_Algorithm_SignalProcessingAlgorithmDesc'
rithm.h(11) : warning C4005: 'OVP_Algorithm_SignalProcessingAlgorithm_InputParam
eterId_Matrix' : macro redefinition
        e:\openvibe\openvibe-plugins\samples\trunc\src\ovp_defines.h(13) : see p
revious definition of 'OVP_Algorithm_SignalProcessingAlgorithm_InputParameterId_
Matrix'
rithm.h(12) : warning C4005: 'OVP_Algorithm_SignalProcessingAlgorithm_OutputPara
meterId_Matrix' : macro redefinition
        e:\openvibe\openvibe-plugins\samples\trunc\src\ovp_defines.h(14) : see p
revious definition of 'OVP_Algorithm_SignalProcessingAlgorithm_OutputParameterId
_Matrix'
rithm.h(14) : warning C4005: 'OVP_Algorithm_SignalProcessingAlgorithm_InputTrigg
erId_Initialize' : macro redefinition
        e:\openvibe\openvibe-plugins\samples\trunc\src\ovp_defines.h(15) : see p
revious definition of 'OVP_Algorithm_SignalProcessingAlgorithm_InputTriggerId_In
itialize'
rithm.h(15) : warning C4005: 'OVP_Algorithm_SignalProcessingAlgorithm_InputTrigg
erId_Process' : macro redefinition
        e:\openvibe\openvibe-plugins\samples\trunc\src\ovp_defines.h(16) : see p
revious definition of 'OVP_Algorithm_SignalProcessingAlgorithm_InputTriggerId_Pr
ocess'
rithm.h(33) : error C2059: syntax error : '='
rithm.h(56) : error C2059: syntax error : '='
rithm.h(62) : error C2143: syntax error : missing ')' before '='
rithm.h(62) : error C2660: 'OpenViBE::Kernel::IAlgorithmProto::addInputParameter
' : function does not take 0 arguments
rithm.h(62) : error C2059: syntax error : ')'
rithm.h(63) : error C2143: syntax error : missing ')' before '='
rithm.h(63) : error C2660: 'OpenViBE::Kernel::IAlgorithmProto::addOutputParamete
r' : function does not take 0 arguments
rithm.h(63) : error C2059: syntax error : ')'
rithm.h(65) : error C2143: syntax error : missing ')' before '='
rithm.h(65) : error C2660: 'OpenViBE::Kernel::IAlgorithmProto::addInputTrigger'
rithm.h(65) : error C2059: syntax error : ')'
rithm.h(66) : error C2143: syntax error : missing ')' before '='
rithm.h(66) : error C2660: 'OpenViBE::Kernel::IAlgorithmProto::addInputTrigger'
rithm.h(66) : error C2059: syntax error : ')'
rithm.h(72) : error C2059: syntax error : '='
E:\Openvibe\openvibe-plugins\samples\trunc\src\ovpCAlgorithmSignalProcessingAlgo
rithm.cpp(12) : error C2143: syntax error : missing ')' before '='
rithm.cpp(12) : error C2660: 'OpenViBEToolkit::TAlgorithm<CAlgorithmParentClass>
::getInputParameter' : function does not take 0 arguments
        with
            CAlgorithmParentClass=OpenViBE::Plugins::IAlgorithm
rithm.cpp(12) : error C2059: syntax error : ')'
rithm.cpp(13) : error C2143: syntax error : missing ')' before '='
rithm.cpp(13) : error C2660: 'OpenViBEToolkit::TAlgorithm<CAlgorithmParentClass>
::getOutputParameter' : function does not take 0 arguments
        with
rithm.cpp(13) : error C2059: syntax error : ')'
rithm.cpp(29) : error C2143: syntax error : missing ')' before '='
rithm.cpp(29) : error C2660: 'OpenViBEToolkit::TAlgorithm<CAlgorithmParentClass>
::isInputTriggerActive' : function does not take 0 arguments
        with
rithm.cpp(29) : error C2059: syntax error : ')'
rithm.cpp(34) : error C2143: syntax error : missing ')' before '='
rithm.cpp(34) : error C2660: 'OpenViBEToolkit::TAlgorithm<CAlgorithmParentClass>
        with
rithm.cpp(34) : error C2059: syntax error : ')'
NMAKE : fatal error U1077: 'C:\PROGRA~1\MICROS~1.0\VC\bin\cl.exe' : return code
'0x2'
Stop.
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio 9.0\VC\BIN
\nmake.exe"' : return code '0x2'
Stop.
Stop.
I did generate new IDs and also defined them in the ovp_main.cpp. I am unable to understand what I did wrong. Could you please help me?
Thank you.
Karthik
PS: In the documentation for the algorithm implementation,
Code:
Similarly, op_pMatrix is the output matrix pointer of this algorithm. The parameter can be retrieved with the getOutputParameter function and given to the handler. Past this point, ip_pMatrix can be used as an IMatrix* pointer using the -> operator.
should read op_pMatrix can be used... Am I wrong?
_________________
Karthik
PostPosted: Wed Jan 26, 2011 2:49 pm
Hello karthiks,
Many thanks for your post... It pointed out a huge mistake I made in the tutorial :oops:
I copy-pasted the wrong code in the tutorial page...
For every ID declaration you have :
Code:
#define OVP_ClassId_BoxAlgorithm_SignalProcessingBoxAlgorithm = OpenViBE::CIdentifier(0x330E3A87, 0x31565BA6)
and it should be :
Code:
#define OVP_ClassId_BoxAlgorithm_SignalProcessingBoxAlgorithm OpenViBE::CIdentifier(0x330E3A87, 0x31565BA6)
... without the "=" !!
When the compiler replaces every ID by its defined value, the "=" is also used, resulting in all the errors you have.
I correct this right now, sorry.
Secondly, it seems like their is multiple definition of the IDs used by the box and the algorithm.
If you read the error log, you have at start :
Code:
macro redefinition
        e:\openvibe\openvibe-plugins\samples\trunc\src\ovp_defines.h(10) : see previous definition of 'OVP_ClassId_Algorithm_SignalProcessingAlgorithm'
It means that this ID is already defined in ovp_defines.h, line 10.
In fact the ovp_defines.h file in the SVN forge declares all the IDs used in the tutorial. I'll update that file.
Anyway, it's simple to solve this problem : you have to be sure that the IDs you are using are defined only once, so delete one of the declaration.
This should fix all the warnings you experienced.
_________________
PostPosted: Wed Jan 26, 2011 2:58 pm
Indeed :D
also fixed !
thanks !
_________________
PostPosted: Wed Jan 26, 2011 3:04 pm
lbonnet wrote:
Hello karthiks,
Code:
macro redefinition
I deleted from both the .h files and kept it in ovp_defines.h
_________________
Karthik
PostPosted: Wed Jan 26, 2011 3:06 pm
Indeed :D
also fixed !
thanks !
Heh, you're welcome. Btw, here - http://openvibe.inria.fr/documentation/ ... ilter.html, the last line should be "This is basically a Surface Laplacian around C4 and C3." instead of "This is basically a Surface Laplacian around C4 and C5."
_________________
Karthik
PostPosted: Wed Jan 26, 2011 3:56 pm
Everything works fine now. I think you should add two lines at the end of the tutorial saying -
1. Add these two lines to the ovp_main.cpp -
Code:
#include "ovpCAlgorithmSignalProcessingAlgorithm.h"
#include "ovpCBoxAlgorithmSignalProcessingBoxAlgorithm.h"
2. Change the following line in openvibe.conf -
Code:
Designer_ShowUnstable = false
from false to true.
The tutorial was very good and explanatory :) Thank you.
_________________
Karthik
Americanized by Maël Soucaze.
