The procedures to build a box
shelldream
Post by shelldream »
I am a beginner to this software.It's amazing to develop this sofeware!!Now I met two problems.
First,I did as the'Build Instructions'said,I downloaded the source code packages ,then I double clicked the win32-install_dependencies.exe located in the scripts folder and it worked well. In the next step 'Building the software',I double clicked the win32-build.cmd in the scripts folder.But ,after doing that,I couldn't find the dist folder in any folders. So I did not konw what should I do next.
Second,I did as 'Tutorial 1: Implementing a signal processing box' said.Because of the first question,after adding the new box header and something else ,I did not konw what to do to let the box be visible and executable as the picture show which you posted on the web.
By the way,my system is WindowsXP(32BITS)with Visual Studio2008.
Shelldream
