Unable to build version 0.8.0 : Ogre.h not found
Posted: Sat Oct 02, 2010 6:58 am
Hi,
I downloaded yesterday the new release sources. I removed my previous version (0.7.0), and launched the necessary scripts. linux-install-dependencies ended correctly, but when i started the linux-build script, i got the following problem :
And then of course a whole series of errors coming from that one,
I checked in the directory .../trunk/scripts/software/include/OGRE, and Ogre.h is actually present there, Any clue why this is happening? Oh, and I don't know if it's relevant, but i'm working on Ubuntu 10.04 x86_64.
Thanks for your help !
lmazon
Code: Select all
Configuring and building openvibe-kernel-omk/trunc ...
-- Found Ogre3D/OIS...
-- [ OK ] Third party lib /usr/lib/libOIS.so
-- [ OK ] Third party lib /usr/lib/libOgreMain.so
-- Configuring done
-- Generating done
-- Build files have been written to: /home/kluck/Cours/4.1/BCI/trunk/local-tmp/openvibe-kernel-omk/trunc
CMake has been called successfully !
[ 1%] Building CXX object CMakeFiles/OpenViBE-kernel-dynamic.dir/src/openvibe-kernel/kernel/visualisation/ovkCVisualisationManager.o
[ 3%] [ 5%] Building CXX object CMakeFiles/OpenViBE-kernel-dynamic.dir/src/openvibe-kernel/kernel/player/ovkMaterialAction.o
Building CXX object CMakeFiles/OpenViBE-kernel-dynamic.dir/src/openvibe-kernel/kernel/player/ovkCOgreResourceGroup.o
[b]In file included from /home/kluck/Cours/4.1/BCI/trunk/openvibe-kernel-omk/trunc/src/openvibe-kernel/kernel/player/ovkMaterialAction.h:4,
from /home/kluck/Cours/4.1/BCI/trunk/openvibe-kernel-omk/trunc/src/openvibe-kernel/kernel/player/ovkMaterialAction.cpp:1:
/home/kluck/Cours/4.1/BCI/trunk/openvibe-kernel-omk/trunc/src/openvibe-kernel/kernel/player/ovkCMaterial.h:24:18: error: Ogre.h: Aucun fichier ou dossier de ce type[/b]
lmazon
