It is currently Fri Feb 21, 2020 1:05 am
 Post subject: ogre
PostPosted: Fri May 14, 2010 2:31 pm
I'm installing openvibe 0.5.0 in a new computer with ubuntu 9.10
No problems in the first steps (dependencies and building), but when I try to run linux-test I get the following errors:
OpenViBE-acquisition-server-dynamic: OgreGLSupport.cpp:57: virtual void Ogre::GLSupport::initialiseExtensions(): Assertion `pcVer && "Problems getting GL version string using glGetString"' failed.
OpenViBE-designer-dynamic: OgreGLSupport.cpp:57: virtual void Ogre::GLSupport::initialiseExtensions(): Assertion `pcVer && "Problems getting GL version string using glGetString"' failed.
Any hint of how can I fix this ?
Thank you for your help.
 Post subject: Re: ogre
PostPosted: Fri May 14, 2010 2:45 pm
I solved.
I had to active the driver for the video card.
Sorry for the noise.
PostPosted: Mon May 17, 2010 8:31 am
Dear jdsitt,
it is nice that you solved this issue yourself and even nicer that you posted the solution on the forum ;) I recommend you move to 0.6.0 if you have no particular reason to stay on 0.5.0. The latest release has major bug corrections in the acquisition server and proposes several additional features that you may want to look at.
Yann Renard
_________________
cron
