It is currently Fri Feb 28, 2020 7:48 am
PostPosted: Tue Mar 30, 2010 1:36 pm
The last version on SVN of nsis is not update, there is a problem with lua.
I have the message : "...lua51.dll est introuvable..." So stimulation disappear of designer
I read the nsis program and effectively, the lua dependencies is not present. So I modify nsis to this, but it is not enough :
Code:
   !include "MUI.nsh"
   !include "zipdll.nsh"
   ;Name and file
   Name "OpenViBE Gipsa"
   OutFile "openvibe-Gipsa-setup.exe"
   ;Default installation folder
   InstallDir "$PROGRAMFILES\openvibe"
   Var OLDINSTDIR
;Interface Settings
   !define MUI_ABORTWARNING
;Pages
   !insertmacro MUI_PAGE_WELCOME
   !insertmacro MUI_PAGE_LICENSE "..\COPYING"
   !insertmacro MUI_PAGE_DIRECTORY
   !insertmacro MUI_PAGE_INSTFILES
   !insertmacro MUI_PAGE_FINISH
   !insertmacro MUI_UNPAGE_WELCOME
   !insertmacro MUI_UNPAGE_CONFIRM
   !insertmacro MUI_UNPAGE_INSTFILES
   !insertmacro MUI_UNPAGE_FINISH
;Languages
   !insertmacro MUI_LANGUAGE "English"
;Installer and uninstaller icons
   Icon "${NSISDIR}\Contrib\Graphics\Icons\box-install.ico"
   UninstallIcon "${NSISDIR}\Contrib\Graphics\Icons\box-uninstall.ico"
Function .onInit
   UserInfo::GetAccountType
   Pop $R1
   StrCmp $R1 "Admin" has_admin_rights 0
      MessageBox MB_OK "You must be administrator to install OpenViBE"
      Quit
has_admin_rights:
   ReadRegStr $0 HKLM SOFTWARE\openvibe InstallDir
   ${If} $0 != ""
      IfFileExists "$0\Uninstall.exe" +1 +5
         MessageBox MB_YESNO "A previous installation of OpenViBE is installed under $0.$\nContinuing the install procedure will remove previous installation of OpenViBE (including all files you eventually added in the installation directory).$\nWould you like to accept this removal and continue on installation process ?" IDNO +1 IDYES +2
         Abort
      StrCpy $OLDINSTDIR $0
      StrCpy $INSTDIR $0
   ${EndIf}
FunctionEnd
Section "-OpenViBE"
   ${If} $OLDINSTDIR != ""
      RMDir /r $OLDINSTDIR
      RMDir /r "$SMPROGRAMS\OpenViBE"
   ${EndIf}
   SetOutPath $INSTDIR
   WriteRegStr HKLM "SOFTWARE\openvibe" "InstallDir" "$INSTDIR"
   WriteUninstaller Uninstall.exe
   CreateDirectory "$INSTDIR\dependencies\arch"
   SetOutPath "$INSTDIR\dependencies"
   IfFileExists "$SYSDIR\d3dx9_38.dll" no_need_to_install_directx
   IfFileExists "arch\openvibe-directx.exe" no_need_to_download_directx
   NSISdl::download "http://www.microsoft.com/downloads/info.aspx?na=90&p=&SrcDisplayLang=en&SrcCategoryId=&SrcFamilyId=04ac064b-00d1-474e-b7b1-442d8712d553&u=http%3a%2f%2fdownload.microsoft.com%2fdownload%2fB%2f7%2f9%2fB79FC9D7-47B8-48B7-A75E-101DEBEB5AB4%2fdirectx_aug2009_redist.exe" "arch\openvibe-directx.exe"
   Pop $R0 ; Get the return value
      StrCmp $R0 "success" +3
         MessageBox MB_OK "Download failed: $R0$\nDirect X won't be installed and 3D functionalities won't be available...$\nYou can install DirectX later to enable 3D functionalities !"
         Goto no_need_to_install_directx ; Quit
no_need_to_download_directx:
   ExecWait '"arch\openvibe-directx.exe" /T:"$INSTDIR\tmp" /Q'
   ExecWait '"$INSTDIR\tmp\DXSETUP.exe" /silent'
no_need_to_install_directx:
   SetOutPath "$INSTDIR\dependencies\arch"
   File ..\dependencies\arch\openvibe-vcredist-2005-sp1.exe
   File ..\dependencies\arch\openvibe-vcredist-2008-sp1.exe
   IfFileExists "arch\openvibe-vcredist-2005-sp1.exe" no_need_to_download_vcredist_2005_sp1
   NSISdl::download "http://download.microsoft.com/download/a/3/7/a379292d-24f2-4bbb-841b-c2aeb1100471/vcredist_x86.exe" "arch\openvibe-vcredist-2005-sp1.exe"
         MessageBox MB_OK "Download failed: $R0"
         Quit
no_need_to_download_vcredist_2005_sp1:
   ExecWait '"arch\openvibe-vcredist-2005-sp1.exe" /q'
;no_need_to_install_vcredist_2005_sp1:
   IfFileExists "arch\openvibe-vcredist-2008-sp1.exe" no_need_to_download_vcredist_2008_sp1
   NSISdl::download "http://download.microsoft.com/download/9/e/d/9edd8390-011b-4c6d-9806-d8dc2b10c0fb/vcredist_x86.exe" "arch\openvibe-vcredist-2008-sp1.exe"
         Quit
no_need_to_download_vcredist_2008_sp1:
   ExecWait '"arch\openvibe-vcredist-2008-sp1.exe" /q'
;no_need_to_install_vcredist_2008_sp1:
   File ..\dependencies\arch\openvibe-dependency-boost-1.41.0.zip
   File ..\dependencies\arch\openvibe-dependency-cmake-2.6.2.zip
   File ..\dependencies\arch\openvibe-dependency-expat-2.0.1.zip
   File ..\dependencies\arch\openvibe-dependency-gtk-2.10.11.zip
   File ..\dependencies\arch\openvibe-dependency-itpp-4.0.6.zip
   File ..\dependencies\arch\openvibe-dependency-lua-5.1.4-30.zip
   File ..\dependencies\arch\openvibe-dependency-obt-22.zip
   File ..\dependencies\arch\openvibe-dependency-ogre-1.6.2-vc2008.zip
   File ..\dependencies\arch\openvibe-dependency-openmask4~dotsceneloader-164.zip
   File ..\dependencies\arch\openvibe-dependency-vrpn-7.13.zip
   ZipDLL::extractall "arch\openvibe-dependency-boost-1.41.0" "boost"
   ZipDLL::extractall "arch\openvibe-dependency-cmake-2.6.2.zip" "cmake"
   ZipDLL::extractall "arch\openvibe-dependency-expat-2.0.1.zip" "expat"
   ZipDLL::extractall "arch\openvibe-dependency-gtk-2.10.11.zip" "gtk"
   ZipDLL::extractall "arch\openvibe-dependency-itpp-4.0.6.zip" "itpp"
   ZipDLL::extractall "arch\openvibe-dependency-lua-5.1.4-30.zip" "lua"
   ZipDLL::extractall "arch\openvibe-dependency-obt-22.zip" "obt"
   ZipDLL::extractall "arch\openvibe-dependency-ogre-1.6.2-vc2008.zip" "ogre-vc2008"
   ZipDLL::extractall "arch\openvibe-dependency-openmask4~dotsceneloader-164.zip" "openmask"
   ZipDLL::extractall "arch\openvibe-dependency-vrpn-7.13.zip" "vrpn"
   FileOpen $0 "$INSTDIR\dependencies\set-env.cmd" w
   FileWrite $0 "@echo off$\r$\n"
   FileWrite $0 "$\r$\n"
   FileWrite $0 "SET OV_DEP_CMAKE=$INSTDIR\dependencies\cmake\cmake-2.6.2-win32-x86$\r$\n"
   FileWrite $0 "SET OV_DEP_EXPAT=$INSTDIR\dependencies\expat$\r$\n"
   FileWrite $0 "SET OV_DEP_BOOST=$INSTDIR\dependencies\boost\boost_1_34_0$\r$\n"
   FileWrite $0 "SET OV_DEP_GLADE=$INSTDIR\dependencies\gtk$\r$\n"
   FileWrite $0 "SET OV_DEP_ITPP=$INSTDIR\dependencies\itpp$\r$\n"
   FileWrite $0 "SET OV_DEP_LUA=$INSTDIR\dependencies\lua$\r$\n"
   FileWrite $0 "SET OV_DEP_OBT=$INSTDIR\dependencies\obt$\r$\n"
   FileWrite $0 "SET OV_DEP_OGRE=$INSTDIR\dependencies\ogre-vc2008$\r$\n"
   FileWrite $0 "SET OV_DEP_OPENMASK=$INSTDIR\dependencies\openmask$\r$\n"
   FileWrite $0 "SET OV_DEP_DSI=$INSTDIR\dependencies\openmask$\r$\n"
   FileWrite $0 "SET OV_DEP_VRPN=$INSTDIR\dependencies\vrpn$\r$\n"
   FileWrite $0 "SET OGRE_HOME=$INSTDIR\dependencies\ogre-vc2008$\r$\n"
   FileWrite $0 "SET OMK_HOME=$INSTDIR\dependencies\openmask$\r$\n"
   FileWrite $0 "SET OMK_BIN=$INSTDIR\dependencies\openmask$\r$\n"
   FileWrite $0 "SET VRPNROOT=$INSTDIR\dependencies\vrpn$\r$\n"
   FileWrite $0 "SET PATH=%OV_DEP_ITPP%\bin;%PATH%$\r$\n"
   FileWrite $0 "SET PATH=%OV_DEP_CMAKE%\bin;%PATH%$\r$\n"
   FileWrite $0 "SET PATH=%OV_DEP_EXPAT%\bin;%PATH%$\r$\n"
   FileWrite $0 "SET PATH=%OV_DEP_BOOST%\bin;%PATH%$\r$\n"
   FileWrite $0 "SET PATH=%OV_DEP_GLADE%\bin;%PATH%$\r$\n"
   FileWrite $0 "SET PATH=%OV_DEP_LUA%\lib;%PATH%$\r$\n"
   FileWrite $0 "SET PATH=%OV_DEP_OBT%\lib;%PATH%$\r$\n"
   FileWrite $0 "SET PATH=%OV_DEP_OGRE%\bin\release;%OV_DEP_OGRE%\bin\debug;%PATH%$\r$\n"
   FileWrite $0 "SET PATH=%OV_DEP_OPENMASK%\lib;%PATH%$\r$\n"
   FileWrite $0 "SET PATH=%OV_DEP_DSI%\lib;%PATH%$\r$\n"
   FileWrite $0 "SET PATH=%OV_DEP_VRPN%\bin;%PATH%$\r$\n"
   FileClose $0
   SetOutPath "$INSTDIR"
   File /nonfatal /r ..\dist\bin
   ; File /nonfatal /r ..\dist\doc
   ; File /nonfatal /r ..\dist\etc
   ; File /nonfatal /r ..\dist\include
   ; File /nonfatal /r ..\dist\lib
   File /nonfatal /r ..\dist\log
   File /nonfatal /r ..\dist\share
   ; File /nonfatal /r ..\dist\tmp
   FileOpen $0 "$INSTDIR\openvibe-designer.cmd" w
   FileWrite $0 "call dependencies\set-env.cmd$\r$\n"
   FileWrite $0 "cd bin$\r$\n"
   FileWrite $0 "OpenViBE-designer-dynamic.exe$\r$\n"
   FileWrite $0 "pause$\r$\n"
   FileClose $0
   FileOpen $0 "$INSTDIR\openvibe-acquisition-server.cmd" w
   FileWrite $0 "OpenViBE-acquisition-server-dynamic.exe$\r$\n"
   FileClose $0
   FileOpen $0 "$INSTDIR\openvibe-id-generator.cmd" w
   FileWrite $0 "OpenViBE-id-generator-dynamic.exe$\r$\n"
   FileClose $0
   FileOpen $0 "$INSTDIR\openvibe-plugin-inspector.cmd" w
   FileWrite $0 "OpenViBE-plugin-inspector-dynamic.exe$\r$\n"
   FileClose $0
   CreateDirectory "$SMPROGRAMS\OpenViBE"
   CreateShortCut "$SMPROGRAMS\OpenViBE\openvibe designer.lnk"           "$INSTDIR\openvibe-designer.cmd"           "" "%SystemRoot%\system32\shell32.dll" 137
   CreateShortCut "$SMPROGRAMS\OpenViBE\openvibe acquisition server.lnk" "$INSTDIR\openvibe-acquisition-server.cmd" "" "%SystemRoot%\system32\shell32.dll" 18
   CreateShortCut "$SMPROGRAMS\OpenViBE\openvibe id generator.lnk"       "$INSTDIR\openvibe-id-generator.cmd"       "" "%SystemRoot%\system32\shell32.dll" 57
   CreateShortCut "$SMPROGRAMS\OpenViBE\openvibe plugin inspector.lnk"   "$INSTDIR\openvibe-plugin-inspector.cmd"   "" "%SystemRoot%\system32\shell32.dll" 55
   CreateShortCut "$SMPROGRAMS\OpenViBE\uninstall.lnk"                   "$INSTDIR\Uninstall.exe"
SectionEnd
Section "Raccourcis"
CreateShortCut "$DESKTOP\openvibe-designer.lnk" "$INSTDIR\openvibe-designer.cmd" "" "$INSTDIR\share\logo_openvibe.ico"
CreateShortCut "$DESKTOP\acquisition server.lnk" "$INSTDIR\openvibe-acquisition-server.cmd" "" "%SystemRoot%\system32\shell32.dll" 18
SectionEnd
Section "Uninstall"
   RMDir /r $INSTDIR
SectionEnd
Can you fix this bug (quickly)?
PostPosted: Tue Mar 30, 2010 2:03 pm
Dear matthieuG,
it is nice you are working on this, we actually did not have time to clean this up for the next release. See how it is done in the win32-install_dependencies.nsi script, you'll have almost all what you need in this script that already includes the necessary changes. If you can't find them easily, just diff it with its previous version in the SVN repository.
Please when you'll have corrected this in the OpenViBE installer, send us the modifications ; that will help us (don't inline it to your post, just attach a file, thanks).
_________________
PostPosted: Tue Mar 30, 2010 3:20 pm
finally my modification was correct..but with a "lib" and not "bin" directory...
So I am going to correct the first message and I send you file
I updated boost version, add shortcut on desktop and naturally add lua dependencies.
File comment: nsis file to build openvibe installer
win32-openvibe-x.x.x-setup_.nsi.txt [10.87 KiB]
Downloaded 194 times
PostPosted: Wed Mar 31, 2010 10:11 am
Dear matthieuG,
thank you for your contribution.
_________________
