It is currently Fri Feb 21, 2020 12:38 am
Post new topic Reply to topic  [ 12 posts ]
 Post subject: using Eclipse to build
PostPosted: Tue Jan 19, 2010 10:02 pm
Hi All,
Does someone use Eclipses IDE to develop OpenVIBE? If so, how to setup the Building options under Eclipse?
Thx
Emerson
PostPosted: Wed Jan 20, 2010 8:51 am
Dear emerson,
thank you for your interest in our software and welcome on this forum.
OpenViBE probably can't be built with Eclipse. If you are using Windows, you should compile with Visual Studio Express, if you use Linux, you'll have to compile with GNU tools from command line. However, you can edit your sources with Eclipse if you want.
Sorry for the inconvenience,
_________________
PostPosted: Wed Jan 20, 2010 9:55 am
Dear Emerson,
I have tested to build openvibe with eclipse under "ubuntu 9.04", I'm using the openvibe commands files with the eclipse function "external tools".
I don't know if you are under windows but I think it's probably the same.
In the menu Run/external tools
you can configure your build and the run.
Choose a name, example: openvibe-build
in the tab "main", fill fields:
location: ${workspace_loc:/openvibe/trunk/scripts/linux-build}
working directory:${workspace_loc:/openvibe/trunk/scripts}
I think for windows it's:
location: ${workspace_loc:/openvibe/trunk/scripts/win32-build.cmd}
for the run part:
example name : openvibe-run
location: ${workspace_loc:/openvibe/trunk/scripts/linux-test}
example name : openvibe-test-acquisition-server
location: ${workspace_loc:/openvibe/trunk/dist/test-acquisition-server.cmd}
working directory:${workspace_loc:/openvibe/trunk/dist}
example name : openvibe-test-designer
location: ${workspace_loc:/openvibe/trunk/dist/test-designer.cmd}
I hope this helps you,
Baptiste
PostPosted: Wed Jan 20, 2010 1:07 pm
Baptiste,
if this actually works correctly with Eclipse, then it should be added to the FAQ, and it's probably possible for other IDE if they support custom build commands. Can you do that please ?
_________________
PostPosted: Mon Jan 25, 2010 1:21 pm
Dear Baptiste and Yann! Thanks for your replies!
Baptiste, does it mean every time I make a small change to my code (plugin) I'll have to re build everything? I know the script skips unchanged codes, but it takes some time to do it. Is there a way of partially building? I know Visual Studio and Eclipse allows you to build part of your code per time. How could I do that for the OpenVIBE project? By the way, what VIBE stands for? :)
PostPosted: Mon Jan 25, 2010 2:22 pm
Dear Emerson,
Yes, with tools "external tools", you must re build everything after your code change. The build of the project takes some time, but you can speed it up. You can find the method in the OpenViBE FAQ : http://openvibe.inria.fr/documentation/unstable/Doc_FAQ.html section “Compiling OpenViBE is far too long especially on Windows, what could I do to speed it up ?”
I'm sorry. I can't help you for it. I know this function but I don't find to configure it, for build OpenViBE with Eclipse or Visual Studio.
Baptiste
PostPosted: Mon Jan 25, 2010 7:51 pm
Hey Baptiste! You already helped me a lot! Thanks for that. I'll try to understand CMake and figure out a way of doing it.
Cheers!
PostPosted: Tue Jan 26, 2010 10:09 am
Dear emerson,
just edit your win32-init_env_command.cmd file as described in the FAQ page. Then calling win32-build.cmd from eclipse should just do the trick :)
_________________
PostPosted: Wed Jan 27, 2010 10:14 pm
It doesn't work on Eclipse (at least under Windows). It complains saying it's not a executable file. Anyway, it's not a problem for me anymore. I already got used to run the script :D
Thanks for your time!
PostPosted: Thu Jan 28, 2010 2:54 pm
Thank you emerson for your feedbacks,
Baptiste, could you check this ? We may have to modify the FAQ entry concerning Eclipse build.
_________________
PostPosted: Fri Jan 29, 2010 3:09 pm
Dear Emerson,
Can you tell me more precision of your problem and your configuration, please. Because I don't understand why you have this problem. Perhaps paths are not same, because the root folder of my project contains tags and trunk folders or perhaps it's the eclipse version, I am using the “galileo” version with C/C++ configuration.
Thank you,
Baptiste
PostPosted: Tue Feb 02, 2010 1:52 pm
Dear guys,
what's up with this Eclipse issue ?
_________________
cron
Americanized by Maël Soucaze.
