Compiling new version of OpenViBE
Post Reply
karthiks
Post by karthiks »
Hey,
I just updated my OpenViBE source with the new files. I am now unable to compile. I get the following error:
Code: Select all
E:\Openvibe\openvibe-applications\acquisition-server\trunc\src\field-trip-protocol\ovasCDriverFieldtrip.cpp(9) : fatal error C1083: Cannot open include file: 'pthread.h': No such file or directory
NMAKE : fatal error U1077: 'C:\PROGRA~1\MICROS~1.0\VC\bin\cl.exe' : return code '0x2'
Stop.
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio 10.0\VC\BIN\nmake.exe"' : return code '0x2'
Stop.
Stop.
An error occured during building process
Press any key to continue . . .
I am using Win7, x86, VC++ 2010 express is installed.
Regards,
Karthik
lbonnet
Site Admin
Re: Compiling new version of OpenViBE
Post by lbonnet »
Hi karthiks,
As stated in the relaese note, new dependencies were added.
On windows pthread is needed to compile a new driver.
Before compiling the new sources, you have to re-install the dependencies.
Please run win32-install_dependencies.exe, clean the cmake cache (delete local-tmp folder) and compile the software once again.
Hope this helps !
Laurent
karthiks
Post by karthiks »
lbonnet wrote:Hi karthiks,
Hope this helps !
Laurent
Hey Laurent,
D'oh. I should have read the release note. Everything installed fine now. But, I have a new issue now.
When I try to run the OpenViBE acquisition server, I get the message - The program can't start because pthreadVCE2.dll is missing from your computer. Try reinstalling the program to fix the problem. I have cleaned and reinstalled everything twice now. But the issue remains.
When I start the designer, it gets stuck on this message and never proceeds forward -
Code: Select all
##  WARNING : Microsoft Visual Studio Common tools initialisation script not fou
nd  ##
[  INF  ] Created kernel loader, trying to load kernel module
[  INF  ] Kernel module loaded, trying to get kernel descriptor
[  INF  ] Got kernel descriptor, trying to create kernel
[  INF  ] Adding [../bin/OpenViBE-plugins-*.dll]
[  INF  ] Added 2 plugin object descriptor(s) from [../bin/OpenViBE-plugins-acqu
isition-dynamic.dll]
[  INF  ] Added 8 plugin object descriptor(s) from [../bin/OpenViBE-plugins-clas
sification-dynamic.dll]
[  INF  ] Added 1 plugin object descriptor(s) from [../bin/OpenViBE-plugins-clas
sification-gpl-dynamic.dll]
[  INF  ] Added 1 plugin object descriptor(s) from [../bin/OpenViBE-plugins-feat
ure-extraction-dynamic.dll]
[  INF  ] Added 17 plugin object descriptor(s) from [../bin/OpenViBE-plugins-fil
e-io-dynamic.dll]
[  INF  ] Added 11 plugin object descriptor(s) from [../bin/OpenViBE-plugins-sam
ples-dynamic.dll]
[  INF  ] Added 29 plugin object descriptor(s) from [../bin/OpenViBE-plugins-sig
nal-processing-dynamic.dll]
[  INF  ] Added 22 plugin object descriptor(s) from [../bin/OpenViBE-plugins-sig
nal-processing-gpl-dynamic.dll]
[  INF  ] Added 17 plugin object descriptor(s) from [../bin/OpenViBE-plugins-sim
ple-visualisation-dynamic.dll]
[  INF  ] Added 12 plugin object descriptor(s) from [../bin/OpenViBE-plugins-sti
mulation-dynamic.dll]
[  INF  ] Added 19 plugin object descriptor(s) from [../bin/OpenViBE-plugins-str
eam-codecs-dynamic.dll]
[  INF  ] Added 3 plugin object descriptor(s) from [../bin/OpenViBE-plugins-stre
aming-dynamic.dll]
[  INF  ] Added 7 plugin object descriptor(s) from [../bin/OpenViBE-plugins-tool
s-dynamic.dll]
[  INF  ] Added 4 plugin object descriptor(s) from [../bin/OpenViBE-plugins-vrpn
-dynamic.dll]
I have tried waiting for 10 minutes but nothing happens.
Thank you for the help.
Regards,
Karthik
lbonnet
Site Admin
Post by lbonnet »
Hi karthiks,
I forgot to tell you something...
When adding a new dependency we also add its DLL folder to the windows PATH variable, so openvibe can find every DLL it needs.
This is done by the script win32-init_env_command.cmd. This file has also been updated with the pthread dependency. Please delete this file in your scripts folder.
A new one will be generated at build time with the updated win32-init_env_command.cmd-skeleton file.
L-
karthiks
Post by karthiks »
Dear Laurent,
It solved my openvibe server issue. But the designer problem is still there as described in the previous post.
Any suggestions?
Regards,
Karthik
lbonnet
Site Admin
Post by lbonnet »
Hi khartiks,
The next step after loading all the plugins (vrpn is the last loaded) should be the designer re-opening the latest scenario(s) used.
These scenarios are defined in the generated file openvibe-designer.conf in C:\document and settings\[login]\.
You can remove this file, maybe it's somehow corrupted.
Other option: please set in your configuration file openvibe.conf the following tokens :
Code: Select all
Kernel_MainLogLevel = Debug
Kernel_ConsoleLogLevel = Trace
Then run the designer, wait a bit, and close.
Send us then the log file (log/openvibe-designer.log).
Maybe we will see where the program fails.
Laurent
karthiks
Post by karthiks »
Dear Laurent,
lbonnet wrote: The next step after loading all the plugins (vrpn is the last loaded) should be the designer re-opening the latest scenario(s) used.
I did this, but it did not work.
lbonnet wrote: Other option: please set in your configuration file openvibe.conf the following tokens :
Code: Select all
Laurent
It seems to fail at creating Ogre root object. I have attached the log file.
Thank you
(22.78 KiB) Downloaded 257 times
Regards,
Karthik
lbonnet
Site Admin
Post by lbonnet »
Hi karthiks,
Indeed it fails in the middle of the Ogre startup process, but without any error message.
If we compare your log to a clean one, it seems like Ogre fails to load its plugins, starting with OpenGL Renderer.
Do you have a local version of Ogre installed on your computer (maybe it could mess up with the openvibe dependency)?
I don't manage to reproduce this behavior on the same setup (win7/x86/visual 2010).
Is this happening also with the latest version of openvibe (fresh SVN checkout from scratch)?
Laurent-
karthiks
Post by karthiks »
Hey Laurent,
Yes, a fresh checkout has the same problem. this is a detailed console level output -
Code: Select all
[ TRACE ] Initializing Ogre
[ TRACE ] Ogre configuration file ../share/openvibe-kernel-omk/ogre.cfg
[ TRACE ] Ogre plugins file E:\Openvibe\scripts\..\dependencies\ogre/bin/release
/Plugins.cfg
[ TRACE ] Creating Ogre root object...
[ DEBUG ] <Ogre3D::Log> Creating resource group General
[ DEBUG ] <Ogre3D::Log> Creating resource group Internal
[ DEBUG ] <Ogre3D::Log> Creating resource group Autodetect
[ DEBUG ] <Ogre3D::Log> SceneManagerFactory for type 'DefaultSceneManager' regis
tered.
[ DEBUG ] <Ogre3D::Log> Registering ResourceManager for type Material
[ DEBUG ] <Ogre3D::Log> Registering ResourceManager for type Mesh
[ DEBUG ] <Ogre3D::Log> Registering ResourceManager for type Skeleton
[ DEBUG ] <Ogre3D::Log> MovableObjectFactory for type 'ParticleSystem' registere
d.
[ DEBUG ] <Ogre3D::Log> OverlayElementFactory for type Panel registered.
[ DEBUG ] <Ogre3D::Log> OverlayElementFactory for type BorderPanel registered.
[ DEBUG ] <Ogre3D::Log> OverlayElementFactory for type TextArea registered.
[ DEBUG ] <Ogre3D::Log> Registering ResourceManager for type Font
[ DEBUG ] <Ogre3D::Log> ArchiveFactory for archive type FileSystem registered.
[ DEBUG ] <Ogre3D::Log> ArchiveFactory for archive type Zip registered.
[ DEBUG ] <Ogre3D::Log> DDS codec registering
[ DEBUG ] <Ogre3D::Log> FreeImage version: 3.13.1
[ DEBUG ] <Ogre3D::Log> This program uses FreeImage, a free, open source image l
ibrary supporting all common bitmap formats. See http://freeimage.sourceforge.ne
t for details
[ DEBUG ] <Ogre3D::Log> Supported formats: bmp,ico,jpg,jif,jpeg,jpe,jng,koa,iff,
lbm,mng,pbm,pbm,pcd,pcx,pgm,pgm,png,ppm,ppm,ras,tga,targa,tif,tiff,wap,wbmp,wbm,
psd,cut,xbm,xpm,gif,hdr,g3,sgi,exr,j2k,j2c,jp2,pfm,pct,pict,pic,bay,bmq,cr2,crw,
cs1,dc2,dcr,dng,erf,fff,hdr,k25,kdc,mdc,mos,mrw,nef,orf,pef,pxn,raf,raw,rdc,sr2,
srf,arw,3fr,cine,ia,kc2,mef,nrw,qtk,rw2,sti,drf,dsc,ptx,cap,iiq,rwz
[ DEBUG ] <Ogre3D::Log> Registering ResourceManager for type HighLevelGpuProgram
[ DEBUG ] <Ogre3D::Log> Registering ResourceManager for type Compositor
[ DEBUG ] <Ogre3D::Log> MovableObjectFactory for type 'Entity' registered.
[ DEBUG ] <Ogre3D::Log> MovableObjectFactory for type 'Light' registered.
[ DEBUG ] <Ogre3D::Log> MovableObjectFactory for type 'BillboardSet' registered.
[ DEBUG ] <Ogre3D::Log> MovableObjectFactory for type 'ManualObject' registered.
[ DEBUG ] <Ogre3D::Log> MovableObjectFactory for type 'BillboardChain' registere
d.
[ DEBUG ] <Ogre3D::Log> MovableObjectFactory for type 'RibbonTrail' registered.
[ DEBUG ] <Ogre3D::Log> Loading library .\RenderSystem_Direct3D9
[ DEBUG ] <Ogre3D::Log> Installing plugin: D3D9 RenderSystem
[ DEBUG ] <Ogre3D::Log> D3D9 : Direct3D9 Rendering Subsystem created.
[ DEBUG ] <Ogre3D::Log> D3D9: Driver Detection Starts
[ DEBUG ] <Ogre3D::Log> D3D9: Driver Detection Ends
[ DEBUG ] <Ogre3D::Log> Plugin successfully installed
[ DEBUG ] <Ogre3D::Log> Loading library .\RenderSystem_GL
[ DEBUG ] <Ogre3D::Log> Installing plugin: GL RenderSystem
[ DEBUG ] <Ogre3D::Log> OpenGL Rendering Subsystem created.
Another install on a separate PC doesn't have this issue and , on that PC, after this the line says Plugin successfully installed. ( I am not sure if this information is helpful)
Thanks.
Regards,
Karthik
karthiks
Post by karthiks »
Any updates or new suggestions?
Regards,
Karthik
lbonnet
Site Admin
Post by lbonnet »
Hi there,
Sorry, the team is a bit reduced with everyone's summer vacation.
I'm still not capable of reproducing this problem on any computer here :s
Meanwhile, you can deactivate Ogre so that openvibe won't even try to load it. You will lost the 3D visualization though.
In your local configuration file (openvibe.conf), add the following token :
Code: Select all
Kernel_3DVisualisationEnabled = false
And Ogre won't be initialized at all.
We will try to reproduce this behavior to correct potential bug...
Tell us if it works without the 3D visualizations.
Laurent-
karthiks
Post by karthiks »
lbonnet wrote:Hi there,
:-s
Code: Select all
Laurent-
This works fine. The designer loads.
Thanks. Hopefully we can figure out what is wrong.
Regards,
Karthik
karthiks
Post by karthiks »
Hey Laurent,
Hope everyone's summer vacation was good. I am still unable to resolve this problem without disabling Ogre. Any ideas?
Regards,
Karthik
yrenard
Site Admin
Contact:
Post by yrenard »
Dear karthiks,
I believe there is an issue with your graphic card driver. Please try to update them.
Best regards,
Yann
Post Reply
