I've recently decided to come back and fiddle around with the application once more. I've managed to run the software ~1 year ago, but now the application no longer starts up. I've decided to pull all the changes and reinstall it once again.
Unfortunately the ./build-dependecies.sh script is failing with the following error:
-- Build files have been written to: /home/blewandowski/repositories/meta/external_projects/arch/Release/vrpn/src/vrpn-build
[ 6%] Performing build step for 'vrpn'
[ 2%] Built target quat
[ 15%] Built target vrpn
[ 17%] Built target gpsnmea
[ 20%] Built target vrpn_atmel
[ 76%] Built target vrpnserver
[ 84%] Built target vrpn-python
[ 85%] Built target java_vrpn_jar
[ 85%] Generating JNI header file for vrpn.AnalogOutputRemote
Error: Could not find class file for 'vrpn.AnalogOutputRemote'.
java_vrpn/CMakeFiles/java_vrpn.dir/build.make:81: recipe for target 'java_vrpn/vrpn_AnalogOutputRemote.h' failed
make[5]: *** [java_vrpn/vrpn_AnalogOutputRemote.h] Error 1
CMakeFiles/Makefile2:1316: recipe for target 'java_vrpn/CMakeFiles/java_vrpn.dir/all' failed
make[4]: *** [java_vrpn/CMakeFiles/java_vrpn.dir/all] Error 2
Makefile:182: recipe for target 'all' failed
make[3]: *** [all] Error 2
CMakeFiles/vrpn.dir/build.make:131: recipe for target '../../arch/Release/vrpn/src/vrpn-stamp/vrpn-build' failed
make[2]: *** [../../arch/Release/vrpn/src/vrpn-stamp/vrpn-build] Error 2
CMakeFiles/Makefile2:105: recipe for target 'CMakeFiles/vrpn.dir/all' failed
make[1]: *** [CMakeFiles/vrpn.dir/all] Error 2
Makefile:103: recipe for target 'all' failed
make: *** [all] Error 2
Thanks Bart
