Hi Thomas,
It's Manjaro 21.2.6
I got the dependencies to install by commenting out the
include("boost") line and using the package provided my pacman.
I also ran into some trouble with vrpn and had to compile that separately and comment out its line in
CMakeLists.txt as there is no pacman package and the AUR one is broken.
For anyone else searching for this, the vrpn error was:
-- NOTE: The following build options may produce a GPL-licensed server library/binary.
-- VRPN_USE_GPM_MOUSE
-- NOTE: I am not a lawyer, and this is not legal advice!
-- Selected build options produce a GPL server library.
-- You may disable them, otherwise set VRPN_GPL_SERVER to acknowledge this and build anyway.
CMake Error at CMakeLists.txt:1526 (message):
Need VRPN_GPL_SERVER to build server library with GPL options enabled!
So I edited
build/CMakeCache.txt and changed
to
After that I ran
./build.sh from the openvibe source directory and discovered a few other missing packages that caused errors, which I found and installed from the AUR:
liblsl (not 100% sure I need this but the sticky post about getting it to work on Fedora 27 mentioned it so ...)
itpp
lepton
I also ran
pip install lsl as there is no python-lsl in the repositories; not sure if that is required though.
That got me a bit further but I am stuck here now:
https://pastebin.com/Q8TyVmBN
